jmzd4
So I took the NC on its first 3 day camping trip this past weekend and when I loaded up the panniers (Givi Outback Trekkers 37L) with everything that I needed (tent, sleeping bag, food, stove, air mattress, clothes, etc., and not much more than that) and sat on it I thought that it was riding a bit low in the rear. The reason I know this is because the kickstand did not have as much clearance as when I don't have all that stuff on the bike. I usually run the bike with just the panniers so i can commute back and forth to work with everything I might need. I weigh ~190, the Givi panniers allow for 22lbs/each (~10kg/each), plus the weight of the pannier racks and the top rack for a Givi Maxima 55L (which is nothing when not loaded) and I don't really run the Maxima unless I don't have the panniers on, so its kind of a non-sequitor.
So I guess my question is do I buy a new shock (Ohlins or what not) to accommodate the weight that I add on, or can I adjust the the OEM shock? And if I do have to adjust the OEM shock how should I do it? One reason I ask this is that in 2018 I plan on running the Trans Labrador Highway and don't want to have a broken shock when I do because of all of the extra weight.
Thanks
Picture for reference:
Thanks
