Craigmri
I suspect if the pre-load can be adjusted to improve the sag setting for a 200 pound rider Bill has found an affordable upgrade for all of us. Cannot wait to hear how the preload adjustment goes!
Awesome!
Wishing you luck.
I'm finding lots of almost good candidates, like the cbr1000rr, but those pesky hard-mounted reservoirs won't clear the tank.
Not having a reservoir is not a plus unless there are clearance issues.Take a look at VFR800/1200 and ST1300 shocks. I don't know their dimensions but they don't have cast on reservoirs (the VFR800 doesn't even have a reservoir) and that's a plus. Also, both models weigh at least what the NCX does so the spring rates might be similar. If the F4i shock doesn't work out, something like those might.
A lot of VFR owners ride them as is but there are quite a few peg draggers that upgrade the suspension.I think the only problem with VFR shocks is they may not be as plenty-full since VFR guys may not upgrade like the super-sport guys do.
Outstanding work, photos, and write-up, Bill! Thank you!
Bill, Max, thanks for sharing your experience with us. Bill, if you were to do it again would you do another F4i shock or try the VFR800 since you mentioned it has no remote reservoir.
Now, that said, I am also interested in trying a 2007-10 Aprilia Tuono rear shock. It doesn't have a reservoir but does provide rebound dampening adjustment. The eye to eye length of the Tuono shock is 12.5 inches so you wouldn't give up any travel and spring diameter is 3.25 inches, so it will fit in the NCX frame. It will need spacers made (or washers) to center it in the Honda linkage.
