Cyclerosis
Good job, looks professional! And thanks for sharing the process to those doing an install like this. Also looks like a great opportunity to chill out, have a beer and clip a stogie!
Nice work Cyclerosis...
Earlier today I received my package in the mail and got to work installing my accessory outlet. Its the Tusk 12v Power Socket. In about 20-25 mins I was done. It was a relatively painless process, and it helped to have small hands. No holes to drill, just a Phillips screwdriver, and a crescent wrench. I couldn't remove the terminal blocks without a bit more muscle. But you tough guys could probably manage just fine with a screwdriver
I'm with Cyclerosis on not compromising the storage compartment seal. Once I opened up the battery compartment, I found a couple of openings through to the fork, and routed the accessory outlet alongside the existing runs. Tomorrow, I'll pick up a some cable ties to bundle the wires with the others.
Open battery compartment
find opening from battery compartment through to front fork
here's a shot of the Tusk 12v Power Socket gizmo
another shot showing the fusible link
getting there with the connections. Seeing lots of red on the right...
Finished product
Open for business. The end!
I hope I got this right. The photo upload process and attachment management isn't the most intuitive...
I just mounted one of these to my handle bars a couple days ago.Tusk 12 Volt Power Socket : Amazon.com : Automotive Ran the wire through like Cyclerosis, except from the steering head area to the battery. No holes to cut at all. Did it while I was at work actually with two phillips screwdrivers. That's it, very simple install.
Just ordered one.. Thanks for the link....
Funny! We were posting at the same time, and mounted the same thing. Mines on the left though.
ahh... I wonder why I am the only oddball installing the factory-expensive-low-powered (1A!!!) 12V socket inside... so dumb.
The hole is actually right at the top and the OEM socket actually has rubber seal so its pretty water tight.
tears.......Lamlamz, don't beat yourself up. I had looked at the Honda unit, but did not get the impression that any kind of external bracket came with it (to mount on handlebar or engine bar like Cyclerosis did), and it just seemed like so much money for an incomplete kit (my opinion) with drilling/cutting required, so I looked elsewhere...
