shawnfrontier
Tried searching for an answer on here and couldn't find anything. So got my OEM saddle bags installed yesterday along with the rear carrier mount, so all I need now is the top case. My problem is the key lock when turning to lock latches, but if you pull slightly on the handle the lock will not hold and the bags can be opened/removed. The lock works fine with the key. Followed and re-read the instructions multiply times, everything is assembled the way it says. Anyone else have any issues with this or know a fix to this?
