Jay Fridays
Ok then... thanks for the input... I will see what my mechanic says on the next serice... get a second opinion... but it's good to hear that it's not a big deal...
Think of The Jetson's flying car whispy sound....and make it a little more squeeky/whistling....lol
That's all I got, sorry....lmfao
Try the brake pads. The NC pads have to be in the slots perfectly or you will get the noise from contact with rotor. This is all I can think of if the bike still is making noise with the engine off and the bike is rolling.. Some times a warped rotor will make noise also. Remove pads and listen to bike rolling with engine off.
No. If you read from earlier you can see. It only happened when the bike was in gear and accelerating. The noise was noticeable from about 15 miles per hour and up... A lot of Honda mechanics reported similar complaints from other NC owners, but all agreed that the noise was negligible and not a concern. I did notice that when the dealer service the bike the noise when away for a couple hundred miles. I did not connect the two things together; the chain was cleaned when it was serviced.
Other members here mentioned the different tensions on the chain while accelerating and while the throttle is released. Other members mentioned that when they clean the chain and sprocket, a similar noise they were experiencing went away. Sure enough, after cleaning all the grunge and lubing up with WD40, NOISE VANISHED!!!
I am near 8,000 miles now, and nothing has made that noise go away except cleaning chain.
