duk2n
Since I changed the front pads I have discovered an interesing issue that I want to share with you.
Let me remember you my NC700X is the European ABS model. The front brake pads are the same than your DCT model (three calipers), but different to your "plain" NC700X that has only two calipers.
In the image you can see:
-At the top, OEM pads almost finished, after 10,000 miles. After some investigation, I found they are Nissin TOYOS20AHH (Sintered, HH). Almost imposible to get them if not at the Honda dealer and very very expensive, at least here at Spain. The pad at the top left has the tipical metal plate to distribute hot and avoid noise when braking at low speed, approaching a trafic light for example. Interesting, this pad -the internal one- has the plate, but the external one has no plate fitted.
-At the middle, new EBC FA388HH pads.
-At the bottom, GALFER FD344G1380 (Sintered) pads, used, 1,500 miles on it.
You can see the OEM pads have 4 blocks of braking material, the EBC has 2 blocks and the GALFER presents only a block with all the braking material continous.
Nor the GALFER nor the EBC pads come with any metal plate.
Well, the issue is as follows:
I installed the GALFER pads about a month ago. Since the begining they have a rattle that I think it is related to the disk rotor shape not being completely circular but having what here at Spain we say literally "flowered shape". I'm sorry, I don't know how do you name it but I hope you will understand me. The rattle has nothing to do with the tipical scrape you can get at the final braking meters specially when the pads are new. It is a rattle in some way similar to a fan when the bearing is faulty. And it sounds as soon as you brake at speed above 20 mph, the more speed the more noise you get.
At the first I guess the rattle was caused by the absence of the metal plate, but it was impossible to fit the OEM pad plate to the GALFER pad because -I think- the GALFER pad was not designed to have it and was way thick than the OEM one. So once I had some miles on the GALFER pads I guess the metal plate could fit and I did te test. So I installed the OEM metal plate in the internal GALFER pad and go for a little ride to test it. No way, the same rattle.
So I bought the EBC pads thinking that the groove they have in the middle of the pad would help... Tried this morning with and without the OEM metal plate. No so high than the GALFER, but the rattle is still there.
Tired of this rattle I fitted the OEM pads again just to be sure the noise is related to the pads and, bingo, the noise is gone.
So, please American guys, if you have changed your front pads and don't have this irritating rattle, please let me know what brand and model are you using. Remember, we are speaking about the ABS NCX model.
And for those of you still with the OEM pads, I hope this post will help you to select the right pads.
