Hot Wing
I installed Over Racing lowering links this past week. The new links are 15mm longer than stock. The result is the seat is 1" lower.
Seat Height:
Stock 32 1/4 in
With links / before lowering forks .85 in. 31 1/2 in
With links / after lowering forks .85 in. 31 1/4 in
Notes:
Stock steel links .235 thick
Aluminum Over Racing links .335 thick
The suspension bolts are about 3mm to short for these thicker than stock links. The bolts don't quite pass all the way through the nuts. They are about two or three threads to short. I attempted to find longer bolts locally. This was a waste of time and fuel. The stock bolts appear to be grade 10.9. There is a reason Honda chose high grade bolts. I am unwilling to use a lower grade part on a major safety item. I ended up using a liberal dose of high strength red lock-tight.
From the saddle it felt a little like sitting on a cruiser, with the new links and before lowering the forks. The forks felt raked out. I did not ride the NC like this.
Chain Adjustment:
Adjust your chain to "perfect" before you install lowering links. Install the links and measure your new correct chain slack. Write it down, add a Dymo label to your swing arm… Whatever works for you.
Stock ideal slack 35mm
New ideal slack 25mm after installing the new links.
Kick Stands:
With the lowering links and lowered fork height, there is no real issue using the center stand. It is noticably harder to lift, but not unreasonable. No adjustment required.
Before lowering the forks, with the new links installed, the side stand length was fine. After lowering the forks, the side stand is to long. It works, but I recommend you don't:
*Turn the wheel to the right, while on the side stand.
*Park with any sort of hill or rise, on the left side of the bike.
*Park with a strong wind blowing from the left.
I need to shorten the side stand, or find a shorter one. I should have placed a protractor on the seat and used a level before I installed the links. Then I would have a target for the proper lean angle. If anyone has a spare stock side stand they want to part with... let me know!
Seat Height:
Stock 32 1/4 in
Notes:
Chain Adjustment:
Kick Stands:
