Light bar with 2x2 cube leds
BFair
PA
Completed the cube light installation. Had to make a custom harness for the light switch. Also, had to weld up brackets to place the lights clear of the forks. 2x2 leds are very high quality, waterproof, about $28.IMG_20200624_150502.jpgIMG_20200624_120826.jpgIMG_20200516_190446.jpgIMG_20200624_120659.jpgIMG_20200624_115530.jpg
melensdad
Chicagoland (NW Indiana) USA
Looks like a nice, tidy install.
I wired my LED lights right into the factory light switch. Turn on with the bike, turn off with the bike.
Is that the factory Honda crash bar/light bar you mounted the lights onto?
BFair
PA
I wanted control of the light. Wired them with the accessories, gps, cell charger, ect. That's a Honda light bar. Way over priced. Tried to order a China knock off but didn't arrive. Lights have to be moved behind mounts or forks hit them. No relays needed only pulls 2 watts for the pair.
Dave H. (CO)
Colorado
I have the same switch for mine, but the light on the switch itself doesn't seem to behave. I went cheap on the light mount and mounted mine to the upper fender bolts.
