Were you able to adequately lower the brake pedal position to properly accommodate a 35mm peg drop?Just mounted these. I must say they are very finely manufactured. Lowers the peg 1.375" (35 mm), which is surprisingly noticeable.
I had to adjust it all the way down to get it in the right place. Definitely could not drop the peg any lower. I adjusted the brake light too. I haven't test ridden yet to make sure the brake engages/disengages like it should. But the lever is right at the sole of my shoe as my foot rests on the peg such that sliding forward is all that's needed to be right on it, so I think it's good.Were you able to adequately lower the brake pedal position to properly accommodate a 35mm peg drop?
I purchased these in the last month and found that even thought the increase in space is not large it is definitely an improvement in comfort. Expensive but very well made and I also had no problem with a rear brake adjustment.I had to adjust it all the way down to get it in the right place. Definitely could not drop the peg any lower. I adjusted the brake light too. I haven't test ridden yet to make sure the brake engages/disengages like it should. But the lever is right at the sole of my shoe as my foot rests on the peg such that sliding forward is all that's needed to be right on it, so I think it's good.
I have installed these on my 2021 DCT as well. I found the them to have a noticeable improvement in the seating position. They have extended my ride comfort.I purchased these in the last month and found that even thought the increase in space is not large it is definitely an improvement in comfort. Expensive but very well made and I also had no problem with a rear brake adjustment.
Nope, but I pretty much ride near the posted speed limit and don't heel the bike over that much. I'm a putz. I'll add that the Knight Design pedals are not drilled and tapped for the "scraper" pegs that are on the original Honda pedals.they look nice. has anyone had any issue dragging the pegs ?
