installing givi S310 spotlights
so you get it from the back of fuse box, attaching to the cable not from the front fuse box as i understand.
thanks
No, front. On this way I did not cut or change anything on the bike. I just put a connector into the empty fuse hole.
I used a man faston
Very easy to find out which one is the right one cable.
Check with something is working on 12volts. Light or sound, put negative (black - ) on bike ground (somewhere for sure is ground) engine part.
Then the positive (red + ) into the fuse space. On/off the ignition.
it took me a while but here you go
Hi guys. I have spotlights on my nc700. They are however linked to high beam. Is it simple to rewire to the low beam or is it more of a job than that? Thanks
Sent from my LG-H870 using Tapatalk
If your Spots come on with ignition (meaning no key no lights) then you just have to change your spot light tap from the Hi-Beam Positive to the Low beam positive.
I think it's the white stripped light heading into your headlight if I remember correctly.
When my low beam is on then the spotlights are not on. Once i put my hi beam light on then the spotlight comes on. But i can't ride with hi beam on because i get flashed by other motorists therefore i dont get use of the spotlights. So i presume i need to rewire the spotlights to the low beam and not hi beam.
With regard to panel removal, it is a simple matter as long as you follow the order. The youtube videos are a very good guide.
You should note that the bolts that you remove are several different sizes and MUST go back exactly where they came from.
A good suggestion is to get a piece of corrugated cardboard and use a sharpie to draw a rough outline of the panel. With a screwdriver, make holes in the cardboard where the bolts are on the panel. Then, as you remove each one. pop it in the card.
Simples!
