Honda Crosstourer Motorcycles Copy
2012 Honda Crosstourer​
Engine​
Engine TypeLiquid-cooled 4-stroke Unicam 16-valve 76° V4
Engine Displacement1,237cc
Bore and Stroke81 x 60mm
Compression Ratio12:1
Ignition Timing8.4° BTDC (idle speed)
Fuel DeliveryPGM-FI electronic fuel injection
IgnitionComputer-controlled digital transistorised with electronic advance
Max. Power Output95kW/7,750min-1 (95/1/EC)
Max. Torque126Nm/6,500min-1 (95/1/EC)
Drivetrain​
Transmission6-speed (DCT = D mode/S mode/Manual mode)
ClutchWet multiplate (DCT = Wet multiplate, hydraulic 2-clutch)
Primary Reduction1.738 (73T / 42T)
Final Reduction2.699 (37/39 x 19/17 x 28/11) / DCT = 2.706 (39/41 x 19/17 x 28/11)
Final DriveEnclosed shaft
Front WheelsTube less spoked 19 x MT2.5
Rear WheelsTube less spoked 17 x MT4
CHASSIS / SUSPENSION / BRAKES​
Frame typeDiamond; aluminium twin-spar
Front Suspension:43mm inverted telescopic forks with hydraulic damping, preload and rebound damping adjustment
Rear SuspensionPro-Link with gas-charged damper, preload and stepless rebound damping adjustment
Front Tire Size110/80-R19
Rear Tire Size150/70-R17
Front Tire Pressure250kPa (36 psi)
Rear Tire Pressure290kPa (42 psi)
Front BrakesDual 310mm disks, Combined ABS
Rear BrakesSingle 276mm disk, Combined ABS
DIMENSION​
Caster Angle28°
Trail107mm (4.2 inches)
Wheelbase1595mm (62.9 inches)
Overall Length2285mm (90 inches)
Overall Width:915mm (36 inches)
Overall Height1335mm (52.5 inches)
Seat Height850mm (33.5 inches)
Ground Clearance180mm (7.1 inches)
Curb Weight275 kg (604 lb) [Front: 132 kg (290 lb); Rear: 143 kg (315 lb)]
Fuel Tank Capacity21.5 Litres (5.7
OTHER​
Fuel Consumption6.2L/100km (37.9 mpg US)
Crosstourer Motorcycles Image Gallery​
The post Honda Crosstourer Motorcycles Copy appeared first on webBikeWorld.
