Fuelly in Signature
First things first..how did you get it there? I'm not a knowledgeable forumer. Second why can't you put it in the signature?
I am not allowed to post a URL code in my signature but can do it in the main body of my message. Any ideas?
I think if you copy and paste only the necessary pieces of the signature, you can add it successfully.
Like this. [*IMG]http://badges.fuelly.com/images/smallsig-us/148081.png[/IMG*] but eliminate the asterisks.
Here goes.....
http://www.fuelly.com/driver/Jguarfn28/nc700x]
John,
I'm butting into a conversation so forgive me if you already have this info. Somone on another thread was having issues with the code in thier sig. Go to the following like and look at the photo I attached. You should only paste the info in the red shaded area. That information is between the IMG tags. You do not need any other information supplied by Fuelly in the BBC box. Just the info between the
http://nc700-forum.com/forum/nc700-general-discussion/2967-join-fuelly-6.html
Ok I used fuelly yesterday for the first time. I got a question how do you guys handle the decimal? Like 2.7 gallons or 3.45 for price?
Yep, I actually put 2.91 gallons. I log the hundredths but it probably doesn't matter that much. Fuelly will automatically add the last zero.
how do you even know what your url code is???
Go to your Fuelly main page. Click on your bikes name in the left column or click on the picture with your stats. See red shaded areas in photo.
Go down that page to the bottom. You will see several small icons. One of which is a shield. Click this. See red arrow.
This is the instruction for the large fuelly signature. Find the box that has the BBC code. Copy the text in the red shaded area. Only copy that text and nothing else. You will be copying everything between the
tags. See red highlighted area.
This is the instruction for the small fuelly signature. Find the box that has the BBC code. Copy the text in the red shaded area. Only copy that text and nothing else. You will be copying everything between the
Go back to the forum website. At the top of the page click the setting link. Once in the settings area you will click the "Edit Signature" on the far left. Paste the code you just copied from the fuelly site. Click "Save Signature". See my signature block for reference.
