black
hi, new to the forum and have searched for gaiter options and have seen some pics (not much) , but i was wondering if people could post pics of what they are running. thanks and i look forward to buying crap for the new bike
I have the Hippo Hands fork protectors. Not the pretiest but easy velcro install and removal at low cost.
When I had my forks upgraded the vendor said he often sees damaged seals from dirt getting behind protectors and never cleaned off. He was strong proponent of protector that is easily removed to clean forks and praised mine. Also said primary value is preventing dings from road debris.
thanks, those all seem like they would work , but i am more interested in the accordion type, i have no issues with pulling the forks. i know the yamaha bolt ones work
That's interesting to know about the gaiters from a Bolt working. This would be a fairly easy fit on the S model then as there's not so much plastic to worry about as on the X model, and the S has shorter suspension travel as well.
Triumph do a pair of plastic fork guards. They are hard plastic and protect the front of the fork leg from direct road dirt and bugs. They clamp onto the NC forks like they were made for them. I suspect that Honda and Triumph use the same fork manufacturer. Kayaba ? I picked up on these items elsewhere on this forum. I am not mad keen on total enclosure bellows type fork protectors as the bellows does what a bellows is meant to do. It moves air around and can pressurise air past the fork seals into the forks. That could necessitate an air release valve on the top of the forks.
I couldn't get that link to work. Is this them?
Fork Protector Kit. Fits: Triumph | Triumph Motorcycle Parts
And what all did you order? The kit? They list a kit. Does that come with the screws, nuts, and protectors. I think I'm going to order these.
That's probably them, try this link
http://www.triumphmcparts.com/products/Triumph/Trophy900/Kit-fork-protector/9930830/A9641010.html
Sent from my Nexus 7 using Tapatalk
Yes it comes with everything you need screw's nuts and protectors
You might wants these , working good for me.http://nc700-forum.com/forum/nc700-mods/3453-gaitors.html
