tew47
Has anyone tried reshaping the rear hugger and mounting a fender extender to the hugger? It might give a little more protection.
tew47
tew47
View attachment 1534 This is what comes to my mind.
Put spacers or washers under the rear attachments of the hugger to raise the rear for more clearance.
I wouldn't want less than the provided front fender clearance on the rear. If a properly clearanced hugger became available that didn't hug so tightly, I would add it and take off the shock sock.
Lee, have a close look at the Skidmarx one. I have no clearance issues, I do believe it has enough room -at least with Metzelers
This is a picture I took to show a modification I did to the chain guard. If you want some specific image, just let me know
What clearance do you have to the tire?
Almost 3 cm from top of the tyre to hugger. Tyre has 8,000 km, but I'm pretty sure it would be around an inch when new:
About the same than in the front fender I would say
Now if we could just source them in the US.
Skidmarx would not do well here as a trade name as it has a negative connotation of something that happens to underwear. Also known as a "muffler burn"
I think you might be able to get the Skidmarx hugger from an outfit in FL (?) called Streetfighters by Design. Contact is [email protected]. Ph. 772-597-3207. I purchased the Skidmarx windscreen through them.
This worked. $165 black or $265 carbon fiber.
