StratTuner
I was out and about to change the front brake pads on the disk brake.
I've done this for the last 95,000 miles on the NC700x.
I tightened just a little too much on the bolt that holds the front pads in...and
s t r i p p....
well , turns out the front caliper (non ABS) is $300, and the mechanic wants $100 to change it out.... (the ABS caliper is almost double at $500 something)
Lesson: don't strip out that bolt !
Shade Tree engineering:
that bolt could just as easily be replaced with a pin of the same diameter.
I'd make it a little longer and with a "head" like you might find on any bolt.
the other end would have a hole where I could fit in a steel cotter pin.
That setup doesn't need threads in the caliper itself and would be easier (cheaper) to service. Maybe next time.
s t r i p p....
