ronsaw
Ouch! Easy does it, I suppose.
Yes, I know. I've done it before as well. Sometimes these are early warning signs to replace the battery. When all is well it starts with no problem but if it is cold or the lights have been left on even a few minutes the battery can't cope with the normal load of starting and craps the bed. It might be jumped off and babied along for a while but each deep discharge takes another bite out of usable capacity.I am proof of this. I accidentally killed my battery yesterday. I left the key on and within 30 minutes or less it was dead.
Why would I need any of that stuff to ride four miles to work?
After my stunt yesterday I've thought to myself that I may want to think about changing the battery. It may or may not need it but I don't want to be out in the middle of nowhere again and it decides it is done. Better safe than sorry and they don't cost that much for a piece of mind.
I choose a Marinco 12 volt outlet over the cheesy Honda one and run it directly off the battery, fuzed of course, with 14 AWG wire. Marinco rates the outlet at 15 amps and it is waterproof and has a locking male connector similarly rated. For an EE I surprised you overlook Puekert's Law. An 11 Ah battery like the OEM battery under a 15 amp load is discharged in a few minutes.....as amp draw goes up capacity drops.
Makes you wish for one of these from the good ol' days:
That's no joke. I tried to push start it three times and that was not happening. Sure could have used a kick start.
These newer bikes with Fuel Injection have bunch of sensors, such as crankshaft positioning sensor. The motor must spin a full revolution in generate the "Index Pulse" for ECU start sending all the appropriate signals to deliver the fuel and spark timing. You probably could not get the motor spin enough times or the battery voltage was “Too Low” for all the electronics to function correctly.
You might think that, but there are exceptions. Modern motocross bikes can be electronic fuel injected, have no battery, and start with a kick starter.
Sounds a lot like an "Energy Transfer System". I think that Triumph had one back in the late 60's or early 70's.
The reason I bought the NC in the first place was the little tank storage so I had somewhere to put my lunch so I would not have to add all that crap to the bike.
