HaChayalBoded
Hey guys, anyone fit a battery that's larger than a 12s? Friend of mine fried his and his bike isn't in front of me at the moment but if I recall he had some extra height in his battery box.
Also see folks that have no problems at all jumping off a car. Like I said, "I can not explain WHY".
The amps are very important! Some times the amps will fry everthing, some times just somethings, and some times nothing. I can not explain why, but I do know what I have seen as a Honda dealer over the years. Seen folks fry every thing all the way to the tail light bulb jumpiing off a car, and I have had to replace every electric componet on the bike. More times than anything, the starter solenod saves the day, by frying first, and no more juice gets though. Just replace starter solenod, but now in CDI unit on most bikes. Also see folks that have no problems at all jumping off a car. Like I said, "I can not explain WHY".
I can certainly explain to you how the electrical system of your average motorcycle functions as well as to how one may fry it's circuity. But that is neither her nor there.
I have been working on motorcycles for the better part of 25 years, as well as having a background in electrical engineering.
As to you being a dealer for 30 years and seeing it happen but not knowing why, well, if I were a dealer and someone came in with those issues my first question would probably be what happened. But I'll tell you if every electrical system in a single bike was really friend, and I mean everything to the tail light bulb as you say it could only happen if someone connected it to a vehicle with either an extreme high output alternator or a vehicle that runs on significantly more than 12v (some trucks, some newer BMWs) and\or the polarity was reveresed at the time.
My question was simply how much extra room is in the battery box?. Does it have any extra height?. Oy Vey Next time I'll just go measure it.
Unfortunately, I think the key words that sort of stuck out more than the rest were: "battery", and "fried", lol.
I can see how a simple question can veer off into how many angels can dance on the head of a pin, and end up being a source of teeth grinding frustration, rather than a: "No, there is X inches of clearance from the top of the OEM battery to the underside of the compartment, and a taller battery probably wouldn't allow room for the positive cable attachment, or the rubber tie down strap to be easily undone" type of answer.
Apologies if you were a bit peeved with the responses mate, but they meant well, even if not answering your specific needs.
No, worries, I probably should have asked on ADV.
But I do find it interesting that a YTZ12s and a YTZ14s have the same exact size specs, but with a slight weight difference. If they use the same size casing I can't see the purpose of even still offering a 12.
Pretty sure the 12 is the OEM size, no reason not to go for the 14 if the size is the same. You gain a teensy bit more Amp Hours but get a 10% increase in cold cranking amps.
Just like gas tanks ( I has fetish,) I always like the idea of as big a battery as I can stuff in a bike; barring a racing or uber lightweight particular requirement, too.
I would definitely go for the 14, when/if my battery goes kaput!![]()
The last time we did the jump start thing..........it was disaster........with a boat load of bad info. Let's try not to repeat that .......
Let's start with the amps are not going to fry anything.
Therapy is on the right track........reverse polarity is the number 1 way stuff gets fried.
http://nc700-forum.com/forum/nc700-technical/3399-battery-charging-new.html?highlight=Jump+start
