dduelin
Yes, I took liberties with amperage but I am comfortable knowing that if the car had a good battery then the addition of an 11Ah NC700X battery to a car battery is 25% or less of the capacity of the combined batteries and the alternator at idle would only be replacing the few amps removed in the action of starting the car and the few amps the flat NC battery would take so the charge current in amps would be low. A battery will only accept the charge it can accept when using a regulated charging source and a car has a current regulator. The good car battery would damp the charge current produced by the car alternator. Still, then I suggested only doing this for 20 or 30 minutes. If the NC battery has a shorted cell and begins to overheat the short period of time would limit the possibility of overheating.Bad idea. The charging rate of the car battery could be significantly higher than that of the motorcycle battery. The alternator on the car can generate enough current to overcharge and fry the motorcycle battery.
Many on here seem to think the voltage is all that matters, but it isn't. If you insist on connecting to a car battery anyway, do not start the car without knowing the charging rate of the motorcycle battery is high enough to handle the output from the cars alternator.
I also know that the battery in the NC and my ST1300 are virtually identical. The ST1300 uses a 740 Ah automotive type alternator to produce 55 amps of current at a nominal charge voltage of 13.6. IT"S JUST LIKE A CAR and it happily produces a flow of electrons that the 11.2 Ah ST1300 battery happily accepts year in and year out...... I'm comfortable doing what I advised but also said the OP might not be.
