- Joined
- May 16, 2012
- Messages
- 5,265
- Reaction score
- 7
- Points
- 0
- Location
- Vancouver BC Canada
I bought a Battery Tender Jr that came with a quick disconnect. And I'll put it on as soon as I can get to the dang battery!
As sacreligious as this may sound...
I suppose you could take a heat gun and carefully warm up the panel to the point of gumby bendy-ness and/or make a small slit through the plastic where the stuck screw is holding it, and just gently pry it off. As long as you didn't go all Godzilla on it, I'm sure a small slit at the one screw hole wouldn't be the end of the world for it to continue functioning perfectly fine later, once you deal with the stripped screw issue.
The access hatch panel is only about $26.00 bucks, so if one were to booger it up during this attempt, at least it wouldn't be beyond all hope to experiment.
Godd luck!
