The Kawasaki W800 Delivers A Modern Take On Classic W1 Style
Kawasaki has kept its W800 the same as 2022 which is not a bad thing. Kawasaki’s motorcycles (even their retro style bikes) include modern features but continue the classic look of their W1 motorcycle. The 773cc parallel twin engine provides a smooth and responsive 46 horsepower while maintaining excellent fuel efficiency. The engine produces enough power to make it suitable for urban riding or cruising.
The W800’s handling is also impressive, with a nimble and agile feel that makes it a joy to ride. The suspension setup is tuned for a comfortable ride, but it’s also capable of handling more aggressive riding when needed. The brakes are also more than capable of bringing the bike to a stop quickly and smoothly and ABS is standard.
The styling of the Kawasaki W800 is undeniably classic but it includes modern touches such as LED lighting, similar to many other 2023 Kawasaki motorcycle models which adds visibility and safety to the bike. The fit and finish of the W800 are top-notch, with high-quality materials and attention to detail throughout.
Other notable features of the W800 include a spacious seat that provides plenty of room for both the rider and passenger. The instrument cluster is a classic design, with an analog speedometer and tachometer complemented by a small digital display that shows additional information such as fuel level and gear position. Overall, the Kawasaki W800 is an impressive motorcycle that modern performance and features while showing it’s Japanese motorcycle heritage.
The 2023 Kawasaki W800 starts at $9,199 USD/$11,599 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Kawasaki W800 in one place.
- Price: $9,199 USD/$11,599
- W1 inspired design
- Disc brakes with ABS
- Chrome steel fenders
- Large 19” front wheel and 18” rear wheel
- Engine: 773 cc 4-stroke, vertical twin, SOHC, 8 valves, air-cooled
- Power: 46.9 horsepower
- Torque: 46 lb-ft
- Weight: 496 lbs (224 kgs)
- Seat Height: 31.1 inches (789 mm)
2023 Kawasaki W800 Specifications
Engine | 773cc, 4-stroke, vertical twin, SOHC, 8 valves, air-cooled |
Power | 46.9 Hp |
Bore x Stroke | 77.0 x 83.0mm |
Compression Ratio | 8.4:1 |
Fuel System | DFI®with 34mm throttle bodies (2) |
Lubrication | |
Clutch | |
Transmission | 5-speed, return shift |
Final Drive | Sealed chain |
Suspension Front | 41mm telescopic fork with/5.1 in |
Suspension Rear | Twin shocks with spring preload adjustability/4.2 in |
Brakes Front | Single 320mm petal-style disc with 2-piston calipers |
Brakes Rear | Single 270mm petal-style disc with 2-piston caliper |
Tires Front | 100/90-19 |
Tires Rear | 130/80-18 |
Fuel Tank Capacity | 4.0 gal |
Color | Candy Fire Red/Metallic Diablo Black |
Ignition | TCBI w/digital advance |
Headlight | LED |
Tail Light | LED |
Overall Length | 86.2 in |
Overall Width | 31.1 in |
Overall Height | 42.3 in |
Wheelbase | 57.7 in |
Ground Clearance | 4.9 in |
Seat Height | 31.1 in |
Curb Weight | 496.1 lb.* |
Warranty | 12 Months |
2023 Kawasaki W800 Features
Assist & Slipper Clutch
Sound Tuning
Kawasaki has long had a reputation for building great-sounding bikes – a characteristic inherent in the Kawasaki engine architecture – but it is only recently that effort has been put into crafting a specific auditory experience through careful sound tuning of either the intake or exhaust system.Designed specifically to allow riders to enjoy their motorcycles aurally as well as physically, the carefully crafted auditory notes can be the key components of the street riding exhilaration offered by models that have benefitted from sound tuning. Sound tuning can include conducting sound research, designing intake and exhaust system components based on an acoustic test carried out in a sound room, and careful consideration of every detail of a system’s components to ensure a balance of performance and the desired sound.
ABS (Anti-lock Brake System)
Kawasaki ABS systems use front and rear wheel sensors to constantly monitor wheel speed. Should information from either of the sensors indicate that wheel lock has occurred, the ABS ECU directs the pump in the ABS unit to modulate brake fluid pressure (releasing and reapplying pressure so that traction can be regained) until normal operation resumes. ABS offers rider reassurance that contributes to greater riding enjoyment.2023 Kawasaki W800 Photos
2023 Kawasaki W800 Videos
2023 Kawasaki W800 review by Peter Lowe one:
2023 Kawasaki W800 Review by Ol’ Man Ronin:
Kawasaki Official Websites
The post 2023 Kawasaki W800 [Specs, Features, Photos] appeared first on webBikeWorld.
