2023 Husqvarna 701 Enduro [Specs, Features, Photos]
The 2023 Husqvarna 701 Enduro: Championship Pedigree
Husqvarna Motorcycles, a Swedish manufacturer with a long history in motorcycle production. The 701 Enduro is the company’s highest-performance street-focused bike in the 2023 Husqvarna lineup. Drawing on its enduro world championship-winning pedigree and over a century of motorcycle experience, this bike offers exceptional off-road and on-road performance.
Powered by a potent 692.7cc single-cylinder engine, this bike offers around 74 horsepower and 53 lb-ft of torque, complemented by a strong steel trellis frame. To maximize the strong engine, Husqvarna adds mates a smooth 6-speed gearbox with Easyshift clutchless up and down shifting.
A full suite of modern technology is standard equipment. From the ride-by-wire throttle, lean-sensitive traction control, 2 easy to select riding modes, and the latest Bosch ABS braking system, the 701 Enduro is beyond capable.
Husqvarnas fits the 701 Enduro with the top-spec WP Xplor suspension front and rear. Fully adjustable and provides exceptional control of the 21” front and 18” rear Black D.I.D wheels. Everything about this machine reveals why Husqvarna has such a rich Championship Enduro history.
The 2023 Husqvarna 701 Enduro starts at $12,999 USD / $13999 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Husqvarna 701 Enduro in one place.
2023 Husqvarna 701 Enduro2023 Husqvarna 701 Enduro
  • Price: $12,999 USD / $13999 CAD
    • 74 hp cc single-cylinder engine
    • Selectable riding modes
    • Fully adjustable WP XPLOR suspension
    • Cornering sensitive Traction Control
  • Engine: 692.7 cc, four-stroke, single-cylinder, liquid-cooled, SOHC
  • Power: 74 hp (55 kW) at 8,000 rpm
  • Torque: 54 lb-ft (73.5 Nm) at 6,500 rpm
  • Dry Weight: 322 lbs (146 kg)
  • Seat Height: 36.4 in. (925 mm)
  • KTM 690 Enduro R
  • Ducati Scambler Desert Sled
  • Yamaha Tenere 700
  • Kawasaki KLR 650
2023 Husqvarna 701 Enduro Specifications​
Engine​
Transmission6-speed
CoolingLiquid cooled
Power in KW55 kW
StarterElectric starter
Bore and Stroke80 mm x 105 mm
ClutchAPTC(TM) slipper clutch, hydraulically actuated
CO2 emissions99 g/km
Displacement692.7 cm³
EMSKeihin EMS with RBW, twin ignition
Design1-cylinder, 4-stroke engine
Fuel consumption
Chassis​
Weight (without fuel)146 kg
Tank capacity (approx.)13 l
ABSTwo channel Bosch 9.1 MP ABS (incl. Cornering ABS and Supermoto mode Disengegable)
Front brake disc diameter300 mm
Rear brake disc diameter240mm
Front brakeBrembo twin-piston floating calliper, brake disc
Rear brakeBrembo single-piston floating calliper, brake disc
ChainX-Ring 5/8 x 1/4″
Frame designChromium-Molybdenum steel trellis frame, powder coated
Front suspensionWP XPLOR-USD, Ø 48 mm
Ground clearance270 mm
Rear suspensionWP XPLOR with Pro-Lever linkage
Seat height920 mm
Steering head angle62.3°
Suspension travel (front) 250 mm
Suspension travel (rear)250 mm
2023 Husqvarna 701 Enduro Features​
Engine​
The single overhead camshaft, liquid cooled, single cylinder engine features the latest in design and electronic technology. An outstanding maximum power output of 55 kW (74 hp) at 8,000 rpm and torque of 73,5 Nm at 6,500 rpm leave the rider in no doubt of the performance packed inside this lightweight unit.
Frame​
The lightweight trellis frame is made of high-grade chromium-molybdenum steel and developed to ensure precise handling and instil complete confidence in the rider. Detailed feedback is transmitted to the rider thanks to precisely calculated torsional rigidity and longitudinal flex.
Polyamide rear subframe and tank​
The self-supporting rear subframe with integrated 3.4 gal (13 liter) fuel tank is perfectly positioned for the best possible weight distribution. Produced in a thermoplastic rotational moulding process, the single-piece construction weighs only 11.4 lbs (5.2 kg) and is made of high-strength polyamide.
WP fork​
The WP XPLOR front fork provides 250 mm wheel travel and capable performance specifically aimed at enduro type riding. The forks consists of an open cartridge layout with a spring in each circuit and split damping functions with the left leg dedicated to compression damping and right fork leg rebound damping.
WP monoshock​
The high performance WP XPLOR rear shock absorber is completely adjustable for compression and rebound. Connected to a linkage system with offroad geometry and 250 mm of rear wheel travel, the system ensures unbeatable all-terrain capability.
Cylinder head​
The compact design of the single overhead camshaft, 4-valve cylinder head features 42 mm intake valves and 34 mm exhaust valves actuated by a robust rocker arm system which delivers precise valve timing at high engine speeds. Ignition is via a dual spark plug layout, each of which has an individual ignition timing control for optimal fuel combustion in the large bore combustion chamber.
Ride-by-wire throttle​
The Keihin electronic fuel injection system features a 50 mm throttle body with no mechanical linkage to the throttle grip. As the rider twists the throttle open or closed, the throttle valve is electronically controlled by the engine management system (EMS). The EMS continuously compares engine parameters with data from sensors, and adjusts the throttle valve accordingly, resulting in perfect power delivery and throttle response.
Gearbox​
The lightweight 6-speed gearbox features an Easy Shift function allowing gears to be seamlessly shifted up or down without using the clutch. The system uses two sensors, one sensor is on the shift arm, which detects the movement on the shift lever rod when the rider upshifts. As the second sensor detects the gear engagement, it matches engine parameters to allow a simple gear change at any RPM or engine load.
Wheels​
Black D.I.D rims made of high strength aluminium alloy add an aggressive and modern look to the 701 Enduro. The offroad capabilities of the 701 Enduro are underlined by the 21″ front and 18″ rear wheel diameter.
2023 Husqvarna 701 Enduro Photos​
2023 Husqvarna 701 Enduro 2023 Husqvarna 701 Enduro 2023 Husqvarna 701 Enduro
2023 Husqvarna 701 Enduro Videos​
Husqvarna 701 Enduro First Impressions. 600 miles on my new Adv bike
KTM 690 ENDURO R 2023 vs Husqvarna 701 Enduro 2023 | What are the differences?
Husqvarna Motorcycles Websites​
Other Links​
The post 2023 Husqvarna 701 Enduro [Specs, Features, Photos] appeared first on webBikeWorld.
