2023 Harley Davidson Nightster [Specs, Features, Photos]
The 2023 Harley Davidson Nightster: The Legacy Continues
After last year’s introduction, the Harley Davidson Nightster returns for the 2023 model lineup. Subtle changes are the main difference this year, the most obvious being the absence of the headlight cowl.
Highlighting the All-American lineage of the Sportster, the Nightster features exposed dual rear shocks, a round intake cover, and peanut styled fuel tank. Power comes from the Revolution® Max 975T liquid-cooled V-Twin tuned for 90 hp; it moves the Nightster with a solid kick.
Harley Davidson ensures each bike benefits from the latest tech. The Nightster comes standard with ABS brakes, LED lighting, selectable rider modes, traction control, and more. To keep the handling in check Showa has designed a 41mm set of front forks which combined with the stiff hoop-style frame, reveal exactly why the Nightster is a proud part of the HD Sport family.
2 color choices exist for the 2023 Harley Davidson Nightster: Vivid Black, and Redline Red.
The 2023 Harley Davidson Nightster starts at $13,499 USD / $16,499 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Harley Davidson Nightster in one place.
2023 Harley Davidson Nightster2023 Harley Davidson Nightster
  • Price: $13,499 USD / $16,499 CAD
    • Revolution Max 975T Engine
    • Tradional Sportster Styling
    • Selectable Rider Modes
    • Rear suspension is dual outboard with adjustable pre-load
  • Engine: 975 cc V-twin
  • Power: 90 HP / 67 kW @ 7500 rpm
  • Torque: 70 ft-lb (95 Nm)
  • Wet Weight: 481 lb. (218 kg)
  • Seat Height: 27.8 in. (705 mm)
  • Indian Scout Bobber Sixty
  • Triumph Bonneville Bobber
  • Honda Rebel 1100
2023 Harley Davidson Nightster Specifications​
Engine975 cc V-twin, Revolution® Max 975T
Engine Torque90 HP / 67 kW @ 7500 rpm
Bore x Stroke3.82 in x 2.6 in.
Compression Ratio
12:1
Exhaust2-into-1; catalyst in header
Clutch
Transmission6-speed
Primary Drive
Gear, 49/89 ratio
Front Fork
41mm SHOWA Dual Bending Valve conventional forks. Aluminum fork triple clamps.
Rear Fork
Rear suspension is dual outboard, direct-acting (no linkage) emulsion technology shock absorbers with coil springs and a threaded collar for pre-load adjustment.
Wheels, Front Type
Aluminum cast, satin black
Wheels, Rear Type
Brakes Front
Single rotor, floating, hub – mounted
Brakes RearSolid uniform expansion rotor
Tires Front
100/90-19 57H
Tires Rear
150/80B16 77H
Fuel Tank Capacity3.1 gal.
ColorRedline Red, Gunship Gray, Vivid Black
Ignition
HeadlightAll LED headlamp
Length
89.4 in.
Trail
5.4 in.
Rake30
Wheelbase
61.3 in.
Ground Clearance
4.5 in.
Seat Height
27.1 in.
Weight, As Shipped
462 lb.
Warranty
2023 Harley Davidson Nightster Features​
EXPOSED DUAL REAR SHOCKS​
Modeled after a previous Sportster chassis, Nightster features exposed dual rear shocks that provide a critical style line at the rear of the motorcycle.
AIR BOX COVER​
The most obvious resemblance to its Sportster lineage is the shape of the airbox cover, which shares its profile with the classic Sportster model fuel tank.
WHEELS​
The Nightster is equipped with a 19-inch front wheel and a 16-inch rear wheel, dimensions selected to deliver nimble performance and distinctive style.
STYLISH LIGHTING​
All LED headlamp, rear lighting and LED bullet turn signals.
2023 Harley Davidson Nightster Photos​
2023 Harley Davidson Nightster 2023 Harley Davidson Nightster 2023 Harley Davidson Nightster 2023 Harley Davidson Nightster
2023 Harley Davidson Nightster Videos​
2023 Harley-Davidson Nightster Review From A Sportster Owner
Brutally Honest Harley-Davidson Nightster First Ride Review
The post 2023 Harley Davidson Nightster [Specs, Features, Photos] appeared first on webBikeWorld.
Looks like it was made by Mattel.
Agreed on the Mattel look. I’d think the Faithful would reject the plastic look of that engine. Not only that, but Harley seems to have went out of their way to make the engine stand out in the look of the bike.
As a kid I had a plastic simulated engine that bolted on my bicycle. It was made by Mattel.
