The 2023 Harley Davidson Nightster Special: Making Night Better
Last year we saw the introduction of the Nightster, and this year Harley Davidson removed the headlight cowl from the base Nightster and expanded the “Sport” section of their 2023 motorcycle lineup with the new Nightster Special.
A headlight cowl alone is certainly not enough to make a classic American legend like the Sportster family, worthy of being called Special. In fact, there are 8 key changes over and above the standard Nightster.
Leading things off, the most in-your-face upgrade has to be the new round TFT display. It is bold and bright and delivers all the main information, beautifully. The new display needs an improved method of navigating the features, so you will find both bars have many new buttons for accessing all the tech. The new display also has Bluetooth connectivity to your phone. Plus there are now 2 additional custom riding modes. The Special enjoys standard tire pressure monitoring and cruise control.
The Special adds new bar risers, bringing the bars up 2 inches and back to the rider 1 inch. There is a pillion pad for 2up rides, and of course a headlight cowl. For the small upcharge, the Nightster Special is a fantastic value.
4 color choices exist for the 2023 Harley Davidson Nightster Special: Vivid Black, Black Denim, Bright Billiard Blue, and Industrial Yellow.
The 2023 Harley Davidson Nightster Special starts at $14,999 USD / $18,299 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Harley Davidson Nightster Special in one place.
- Price: $14,999 USD / $18,299 CAD
- Revolution Max 975T Engine
- 4” TFT Display
- 3 Selectable Rider Modes, Plus 2 Customizable Modes
- Bar Risers
- Pillion Seat
- Engine: 975 cc V-twin
- Power: 90 HP / 67 kW @ 7500 rpm
- Torque: 70 ft-lb (95 Nm)
- Wet Weight: 483 lb. (219 kg)
- Seat Height: 27.8 in. (705 mm)
- Indian Scout Bobber Sixty
- Triumph Bonneville Bobber
- Honda Rebel 1100
2023 Harley Davidson Nightster Special Specifications
Engine | 975 cc V-twin, Revolution® Max 975T |
Engine Torque | 90 HP / 67 kW @ 7500 rpm |
Bore x Stroke | 3.82 in x 2.6 in. |
Compression Ratio | 12:1 |
Fuel System | Electronic Sequential Port Fuel Injection (ESPFI) |
Exhaust | 2-into-1; catalyst in header |
Clutch | |
Transmission | 6-speed |
Primary Drive | Gear, 49/89 ratio |
Front Fork | 41mm SHOWA Dual Bending Valve conventional forks. Aluminum fork triple clamps. |
Rear Fork | Rear suspension is dual outboard, direct-acting (no linkage) emulsion technology shock absorbers with coil springs and a threaded collar for pre-load adjustment. |
Wheels, Front Type | Aluminum cast, silver |
Wheels, Rear Type | Aluminum cast, silver |
Brakes Front | Single rotor, floating, hub – mounted |
Brakes Rear | Solid uniform expansion rotor |
Tires Front | 100/90-19 57H |
Tires Rear | 150/80B16 77H |
Fuel Tank Capacity | 3.1 gal. |
Color | Vivid Black, Black Denim, Industrial Yellow, Bright Billiard Blue |
Ignition | |
Headlight | All LED headlamp |
Tail Light | LED |
Length | 87 in. |
Trail | 5.4 in. |
Rake | 30 |
Wheelbase | 61.3 in. |
Ground Clearance | 4.5 in. |
Seat Height | 27.1 in. |
Weight, As Shipped | 465 lb. |
Warranty | |
Extension |
2023 Harley Davidson Nightster Special Features
VINTAGE STYLING
The air box cover features a medallion with 1970s styling.TWO-UP READY
Passenger pillion and foot pegs enable a two-up adventure.FRONT SUSPENSION
Dual Bending Valve conventional forks designed to provide improved handling performance by keeping the tire in contact with the road surface.STYLISH LIGHTING
All LED headlamp, rear lighting and LED bullet turn signals.2023 Harley Davidson Nightster Special Photos
2023 Harley Davidson Nightster Special Videos
New 2023 Harley-Davidson Nightster Special: Everything You Need To Know!
2023 Harley-Davidson Nightster Special (RH975S) Full Review and Test Ride
Harley-Davidson Official Websites
The post 2023 Harley Davidson Nightster Special [Specs, Features, Photos] appeared first on webBikeWorld.
