2022 Kawasaki Ninja 650 [Specs, Features, Photos]
The 2022 Kawasaki Ninja 650: A Next Level Ninja for the Initiated​
Looking for something a bit more aggressive than Kawasaki’s entry-level Ninja 400, but not ready to tackle a liter bike just yet? That’s what the Ninja 650 ABS is for—it’s big on thrills, but not so big that it’ll get away from you too easily if you’ve only been riding for a few seasons. And truth be told, there are many more experienced riders out there who simply like the way this mid-size sport bike feels and handles. It’s a Kawasaki, after all.
The big Japanese bike brands are all pros, especially when it comes to making sport bikes, so it shouldn’t surprise you to learn that this year’s Ninja 650 ABS is an extremely well-balanced offering. It’s also pretty much exactly the same as last years Ninja 650—although the colors have been updated to Metallic Graphite/Graphene Steel Gray and Pearl Robotic White/Metallic Carbon Gray.
The engine’s still a digitally fuel-injected 649cc parallel twin that spits out 67 hp @ 8,000 rpm and 47 lb-ft of torque at 6,700 rpm. It still has an assist & slipper clutch (just like the Ninja 400), an economical riding indicator, and ABS. Unlike its smaller sibling, the 650 offers smartphone connectivity via Bluetooth—but these were all on last year’s model as well. And like that version, you can also pay an extra $200 to get the bike with distinctive KRT graphics.
Seriously, though—if it ain’t broke, why fix it? The 2022 Ninja 650 is still a truly excellent all-rounder when it comes to mid-size sport bikes, and it certainly offers enough “oomph” to hang with rivals like the Honda CBR650R or Yamaha MT-07—earning it a well-deserved spot in the 2022 Kawasaki Motorcycle Lineup.
The 2022 Kawasaki Ninja 650 ABS starts at $8,299 USD / $9,299 CAD. It’s also available in the US without ABS for $7,899 USD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Kawasaki Ninja 650 ABS in one place.
  • Price: $8,299 USD / $9,299 CAD
    • Assist & slipper clutch
    • Economical riding indicator
    • Bluetooth smartphone connectivity
    • Horizontal back-link rear suspension
Main Specs​
  • Engine: digitally fuel-injected 649cc parallel twin
  • Power: 67 hp @ 8,000 rpm
  • Torque: 47 lb-ft of torque at 6,700 rpm
  • Dry Weight: 423 lbs (192kg)
  • Seat Height: 31.1 inches (790 mm)
Competitors​
2022 Kawasaki Ninja 650 Specifications​
Engine649cc, 4-stroke, Parallel Twin, DOHC, 8-valve, liquid cooled
Power67 hp
Bore x Stroke83.0 x 60.0mm
Compression Ratio
10.8:1
Fuel SystemDFI® with dual 36mm Keihin throttle bodies
Lubrication
Clutch
Transmission6-speed
Final DriveSealed chain
Suspension Front41mm hydraulic telescopic fork/4.9 in
Suspension RearHorizontal back-link with adjustable spring preload/5.1 in
Brakes FrontDual 300mm petal-type discs and 2-piston calipers and ABS
Brakes Rear
Single 220mm petal-type disc and single-piston caliper and ABS
Tires Front
120/70×17
Tires Rear160/60×17
Fuel Tank Capacity4.0 gal
Color
Metallic Matte Graphenesteel Gray, Pearl Robotic White/Metallic Carbon Gray
IgnitionTCBI with electronic advance
HeadlightLED
Overall Length80.9 in
Overall Width29.1 in
Overall Height45.1 in
Wheelbase55.5 in
Ground Clearance5.1 in
Seat Height31.1 in
Curb Weight423.4lb*
Warranty12 Months
2022 Kawasaki Ninja 650 Features​
Assist & Slipper Clutch​
Dual Throttle Valves​
Economical Riding Indicator​
ABS (Anti-lock Brake System)​
2022 Kawasaki Ninja 650 Photos​
2022 Kawasaki Ninja 650 2022 Kawasaki Ninja 650 2022 Kawasaki Ninja 650 2022 Kawasaki Ninja 650
2022 Kawasaki Ninja 650 Videos​
2022 Kawasaki Ninja 650 New Color Walkaround Review
Kawasaki Official Websites​
The post 2022 Kawasaki Ninja 650 [Specs, Features, Photos] appeared first on webBikeWorld.
