2021 MV Agusta Turismo Veloce 800 Rosso [Model Overview]
The 2021 MV Agusta Turismo Veloce 800 Rosso: The Ultimate Urban Sports Tourer​
The 2021 MV Agusta Turismo Veloce 800 Rosso is the entry level into the company’s sports touring range. Designed with Italian streets in mind, the bike is both lightweight and extremely agile, to help dodge around all the tight corners and side streets of a busy city. Powered by a 798cc inline-three, it develops 110 HP and a hair under 60 lb-ft of torque.
As one would expect from an Italian manufacturer, the bike is absolutely a statement of design and technology. It is also painted in the classic Rosso Corse, or racing red, that many race teams around the country use. In terms of technology, the Turismo Veloce 800 comes with the latest version of MV’s MVICS (Motor & Vehicle Integrated Control System), electronically controlled injectors, throttle-by-wire with adjustable valve timing, and a full 8 stage traction control system. Dual-zone ABS comes as standard.
The Turismo Veloce 800 Rosso also, for a base model, impressively includes MV Agusta’s MV-EAS 2.1 (Electronically Assisted Shift) quickshifter, which you can use without the clutch to instantly shift up and down as needed due to the riding conditions.
The 2021 MV Agusta Turismo Veloce 800 Rosso starts at approximately $16,955 USD / $21,520 CAD, as it is listed in Euros (€13,990).
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new MV Agusta Turismo Veloce 800 Rosso in one place.
  • Price: $16,955 USD / $21,520 CAD
    • 8 level traction control system
    • Latest version of MV Agusta’s engine control system
    • Dual-zone ABS standard
Main Specs​
  • Engine Type: 798cc liquid and oil cooled, four stroke, DOHC, 12 valve triple
  • Horsepower: 110 HP
  • Torque: 60 lb-ft
  • Wet Weight: Approx 440 lbs (Approx 200 kg)
  • Seat Height: 33.46 inches (850 mm)
Competitors​
2021 MV Agusta Turismo Veloce 800 Rosso Specifications​
Engine798cc liquid and oil cooled, four stroke, DOHC, 12 valve triple
Power110 horsepower
Bore x Stroke79 mm x 54.3 mm (3.1 in. x 2.1 in.)
Compression Ratio12.3:1
Timing system“D.O.H.C” with mechanical chain tensioner
ColorAgo Red, Metallic Carbon Black
ClutchHydraulic, wet, multi-disc with slipper clutch
TransmissionCassette style; six speed, constant mesh
Final Drive Ratio16/41
Suspension FrontMarzocchi “UPSIDE DOWN” telescopic hydraulic fork with rebound-compression damping and spring preload external and separate adjustment
Suspension RearProgressive Sachs, single shock absorber with rebound and compression damping and spring preload adjustment
Brakes Front
Double floating disc with Ø 320 mm (Ø 12.6 in.) diameter, with steel braking disc and flange
Brakes RearSingle steel disc with Ø 220 mm (Ø 8.66 in.) dia.
Tires Front120/70 – ZR 17 M/C (58 W)
Tires Rear190/55 – ZR 17 M/C (75 W)
Fuel Tank Capacity21.5 l (5.68 U.S. gal.)
ABS SystemBosch 9 Plus with RLM (Rear wheel Lift-up Mitigation)
Battery12 V – 8.6 Ah
Voltage12 V
Alternator350 W at 5000 r.p.m.
Headlight
Tail Light
Overall Length2125 mm (83.66 in.)
Overall Width910 mm (35.83 in.)
Trail108 mm (4.25 in.)
Wheelbase1445 mm (56.89 in.)
Ground Clearance140 mm (5.51 in.)
Seat Height850 mm (33.46 in.)
Dry Weight191 kg (421.1 lbs.)
Warranty
2021 MV Agusta Turismo Veloce 800 Rosso Features​
Control and freedom of choice​
8-level traction control and four riding modes: Sports, Race, Rain and Custom. Changing the engine’s character is quick and intuitive. The result? Four bikes in one, and pure enjoyment guaranteed in every driving situation.
High-tech for all​
The entire Rosso range features the same advanced technology as the other MV Agusta models, like the MotoGP-derived counter-rotating crankshaft and extractable gearbox.
Quality brake system​
Power and modularity describe the high-quality brake system featuring a couple of Brembo radial calipers on the front and advanced Bosch 9 Plus ABS with RLM (Rear wheel Lift Mitigation).
2021 MV Agusta Turismo Veloce 800 Rosso Photos​
2021 MV Agusta Turismo Veloce 800 Rosso Videos​
MV Agusta Websites​
Other Links​
The post 2021 MV Agusta Turismo Veloce 800 Rosso [Model Overview] appeared first on webBikeWorld.
