2022 MV Agusta Turismo Veloce Rosso [Specs, Features, Photos]
The 2022 MV Agusta Turismo Veloce Rosso Is an Affordable, High-Performance Tourer​
The MV Agusta Turismo Veloce Rosso from the brand’s 2022 lineup is a motorcycle that brings its competitive DNA to the road. We’re talking about a flexible sports bike concept that enhances riding pleasure in various situations. It’s eclectic and simple for trips on any road. However, MV promises that traveling and commuting will be much more exciting.
The Turismo Veloce Rosso is an Italian sports-touring bike with all its letters. It offers a convincing performance to provide a fun and adrenaline-driving experience, but with total confidence.
It also offers the freedom to add a more adventurous edge to daily commuting at a price that puts it within reach of more drivers.
The engine is the same for the Turismo Veloce 2022 family, the well-known three-cylinder with twelve valves, 798 cc and 110 hp of power, and a torque of 80 Nm at 7,100 rpm. In addition, this engine has redesigned intake ducts that improve the delivery of torque at low revolutions, which, together with the changes in gear ratios to improve consumption, only improve its skills.
This year’s three-cylinder MV Agusta engines also feature treatment to the valves and their guides, reducing internal friction and Smart Clutch System 2.0.
The Turismo Veloce2021 mounts the new traction and ABS control system, with a cornering function and cruise control displayed on a 5.5-inch color TFT screen, and is available through the MV Ride app.
The 2022 MV Agusta Turismo Veloce Rosso starts at $15,671 USD / $20,159 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 MV Agusta Turismo Veloce Rosso in one place.
  • Price: $15,671 USD / $20,159 CAD
    • 110hp 798 cc 3-cylinder engine
    • Continental MK100 with RLM (Rear Wheel Lift-up Mitigation) and with cornering function
    • Marzocchi telescopic hydraulic fork and progressive Sachs, single shock absorber, both with rebound and compression damping and spring preload adjustment
    • Integrated ignition – injection system MVICS 2.1
Main Specs​
  • Engine: 798 cc, 4-stroke, 3-cylinder, liquid-cooled, 12 valve DOHC
  • Power: 110 hp (81 kW) at 10,150 rpm
  • Torque: 59 lb-ft (80 Nm) at 7,100 rpm
  • Wet Weight: 440lbs (199 kg)
  • Seat Height: 33.46 in. (850 mm)
Competitors​
2022 MV Agusta Turismo Veloce Rosso Specifications​
Engine798 cm3 (48.7 cu. in.), Three cylinder, 4 stroke, 12 valve
Power110 Hp
Bore x Stroke79 mm x 54.3 mm (3.1 in. x 2.1 in.)
Compression Ratio13.4:1
Timing system“D.O.H.C” with mechanical chain tensioner and DLC tappet
ColorAgo Red
ClutchHydraulic, wet, multi-disc with slipper clutch
TransmissionCassette style; six speed, constant mesh
Final Drive Ratio16/39
Suspension FrontMarzocchi “UPSIDE DOWN” telescopic hydraulic fork with rebound-compression damping and spring preload external and separate adjustment
Suspension RearProgressive Sachs, single shock absorber with rebound and compression damping and spring preload adjustment
Brakes Front
Double floating disc with Ø 320 mm (Ø 12.6 in.) diameter, with steel braking disc and flange
Brakes RearSingle steel disc with Ø 220 mm (Ø 8.66 in.) dia.
Tires Front120/70 – ZR 17 M/C (58 W)
Tires Rear190/55 – ZR 17 M/C (75 W)
Fuel Tank Capacity21.5 l (5.68 U.S. gal.)
ABS SystemContinental MK100 with RLM (Rear Wheel Lift-up Mitigation) and with cornering function
Battery12 V – 11 Ah
Voltage12 V
Alternator450 W at 5.000 r.p.m.
Headlight
Tail Light
Overall Length2.125 mm (83.66 in.)
Overall Width910 mm (35.83 in.)
Trail108 mm (4.25 in.)
Wheelbase1.445 mm (56.89 in.)
Ground Clearance140 mm (5.51 in.)
Seat Height830 mm (32.68 in.)
Dry Weight191 kg (421.1 lbs.)
Warranty
2022 MV Agusta Turismo Veloce Rosso Features​
Electronics​
The introduction of the new IMU inertial platform, developed by e-Novia exclusively for MV Agusta, has further improved the precision and efficiency of the electronic controls. In this way, safety and riding pleasure are enhanced simultaneously, equipping the Turismo Veloce Rosso with a high-tech package that guarantees utmost reliability on the road.
Technology​
The new optional configurations include Bluetooth connection, cruise control, the manually adjustable windshield, centre stand and the Mobisat anti-theft system. The wide-ranging catalogue of accessories boasts heated hand grips, a Garmin satellite navigator and the 34 litre luggage cases.
Safety​
The braking system, designed by Brembo, with two 320 mm diameter front discs, radial callipers and four pads. The advanced ABS is equipped with Continental MK100 con Rear Wheel Lift-Up Mitigation and cornering function.
2022 MV Agusta Turismo Veloce Rosso Photos​
2022 MV Agusta Turismo Veloce Rosso 2022 MV Agusta Turismo Veloce Rosso 2022 MV Agusta Turismo Veloce Rosso 2022 MV Agusta Turismo Veloce Rosso
2022 MV Agusta Turismo Veloce Rosso Videos​
MV Agusta Turismo Veloce Rosso (2022) Exterior Interior
MV Agusta Websites​
Other Links​
The post 2022 MV Agusta Turismo Veloce Rosso [Specs, Features, Photos] appeared first on webBikeWorld.
