FrankQC
Looks nice, thanks for the pictures !
I know it's been a while, but do you know what kind of paint they used? Thanks
The top meter is a coolant temp, exactly as the one originally installed by duk2n here : http://nc700-forum.com/forum/nc700-mods/927-coolant-temp-meter.html
The one above the frunk is a voltmeter / ammeter combo. I got it here : DC 4.5-30V 50A Red&Blue Led Dual Panel Volt Amp Combo Meter + 50A/75mV Shunt | eBay
You need to be technically inclined to install this one because you need to 1- waterproof the display unit and 2- install a shunt resistor on the (-) pole of the battery to get the ammeter readout.
I don't want to change the orientation of the thread so PM me if you need more infos about this.
Yes, the shunt goes directly on the (-) pole of the battery. You need to disconnect everything from the (-) of the battery (including the OEM wire) and connect them to one side of the shunt. The other side of the shunt returns to the (-) side of the battery with a thick wire (6ga). The unit will take into account everything connected to the battery, including accessories grounded to the frame.
Connected this way, the ammeter will give you a positive reading when the battery is being charged and a negative reading when the battery is being discharged (like engine not running)
Wow, every time I click into this thread I think we'd be talking about paint.
Sorry Super Moderator... things got carried away. How can I quote FrankQC's response and put it on a new thread? Can you help to move the topic to appropriate thread?
Thanks.
