bulpup
Bad time to realize my torque wrench was broken. Two pillions stripped before I got wise. Any thoughts on using a helicoil for these or is the wheel toast?
Some swear by helicoils but some have had them back out. If they're not put in correctly there can be problems. On a brake disc that would make me nervous. If it was my bike I'd look into tapping it out. Tap and die sets are cheap at Harbor Freight if you don't already have one. If you can find larger bolts that would work (bolt head clearance issue??) I'd probably go that route instead of a helicoil.
