Looking to extend the brake foot peg out from the bike.
bduffey
Massachusetts
Anyone have any info on a foot pad/peg extension that can be attached to the stock foot brake peg?
I currently am using the 1/2 dowel-in-the-hole trick, but I would feel better with something more stable. I am trying to avoid welding an extension onto the factory peg. Any ideas?
I didn't go look at mine, but I am guessing you could either use a bottoming tap or a drill bit and then a bottoming tap to thread the inside then just run a bolt or threaded rod the length you want in it. Might be a little tricky to get the tap started with the angle but in my mind it would work:cool:
Wonder if the peg is aluminum and might become to 'soft' if tapped?
