Lou Wambsganss
- Joined
- Oct 23, 2013
- Messages
- 279
- Reaction score
- 3
- Points
- 0
- Location
- United States, Dallas, TX
Due to my work schedule, a lot of my miles are done in the dark. I found a bunch of cheap flexible LED accent light strips at Autozone on sale. I mounted 2x 8" strips under the tail, 2x 24" strips over the engine, 1x 8" strip under the beak, and 1x 8" strip in the Frunk as a courtesy light. I wired them all in to a switchable, shielded bus bar (also from Autozone). The bus bar is wired into the Honda Accessory relay location. Each slot in the bus bar (6 total) has its own on/off switch, so I can turn each pair of lights on/off as desired. Here are some pics. LEDs look weird to my camera phone, but in real life the bike has a significantly more noticeable side profile in the dark.
This is the bus bar. You can also see the LED strip to the right. The bar is not waterproof, so I didn't want to mount it outside of the frunk. All the terminals are screw-lock, so the wires can be removed and reinstalled easily. I can also double-up the light circuits later if I need the bar space.
Frunk Light on.
Standard lighting
With all accent lighting turned on.
Beak Light
Engine Light
Tail Light
While I was at it, I also disassembled the bottom cover and spray painted the middle gray part with "Aluminum" colored engine paint. The gray looked weird to me. It didn't match anything, and I have the 2012 Silver. Has anyone else just painted the whole thing black? If so, please reply with pics. I'm curious to see what that looks like.
Frunk Light on.
Standard lighting
Beak Light
Engine Light
Tail Light
