- Joined
- May 16, 2012
- Messages
- 5,265
- Reaction score
- 7
- Points
- 0
- Location
- Vancouver BC Canada
short: 1/8 LENGTH
I'll make sure that's so before I proceed.
I hope so, as if it's the Short it's not going to work...
short: 1/8 LENGTH
I used 3M double-sided sticky tape that's really super sticky. It is fixed hard onto the fender, I don't think I could pry it off without doing some damage. After being on there 3 months, it's not going to come loose unless I ride in an extended flood.
I did the same thing, 3M 1" wide, side to side three times. The tape supplied is crap. Then I put a small bead of construction adhesive across the top (uppermost section) from side to sideto keep the moisture out. That thing is never coming off.
Drilling holes and using bolts/rivets is not necessary. That is overkill.
Are you talking the 3M VHB tape?
*Â*3Mâ„¢ VHBâ„¢ Tape
They haven't got sucked into the wheel and caused my fiery horrid death that some predicted. I laughed when it was suggested a piece of plastic this size could lock the front wheel and cause a crash. If ( and that's a big if) it got sucked into the front wheel the forces of the tire and fender would spread this small piece of plastic into much smaller pieces of plastic
gpd211;36919 They haven't got sucked into the wheel and caused my fiery horrid death that some predicted. I laughed when it was suggested a piece of plastic this size could lock the front wheel and cause a crash. If ( and that's a big if) it got sucked into the front wheel the forces of the tire and fender would spread this small piece of plastic into much smaller pieces of plastic[/QUOTE said:Some might think a shoe lace, back pack strap or bungee cord would not stop a wheel from rotating............it can and does happen.
Quick question... What is the best LENGTH of pop rivet to use? 1/4? 1/8? 1/2?
I'm using 5mm diameter, but I notice there are different lengths.
Thanks for the benefit of your experience.
I went straight to stainless steel rivets. Looks like a slight case of overkill with 6 rivets, but the ones nearest the front ended up very close to the front edge of the extender (I know, measure twice, drill once) - I just didn't fully take into account how the shape of the extender cuts back.
Good point, Bot. I guess I could stick the thing on, drill the holes, then measure the thickness with a toothpick to figure out what to use.I'm guessing 1/4' but the only way to tell for sure is to assemble the extender and fender using whatever glue or tape you've decided on and drill the holes for the rivets. Then measure the depth of the hole and add the thickness of any washer you plan on using. Hole depth plus thickness of washer is the grip length you need.
Bob
