JoeTx
Something I have been thinking about for a while. Numerous others have boldly gone before me and this is my take from their endeavors. 1st It has to be elegant, no mismatched parts and fittings it has to look good and detailed. 2nd the auxiliary tank is a gravity feed system; therefore think big pipe and easy flow. That's why I went big with 10 AN. 3rd Easy removal; even-though the tank weights ounces there will be times where I don't want to be carrying the tank so I wanted easy removal.
Our fuel pump -cute !!
I had a idea, and during my maintenance down time ( new chain, fender extenda, tire hugger, valve check and oil change, Wilbers rear, Andreani cartilages up front) thought I'd pull the tank and get my fitting welded on with help from Miller's Machine & Welding cost was 50 bucks. Mr. Miller reported the tank was like paper and this was no job for an amateur. He did did a fantastic job as you can see.
The reason I used an "O"ring type fitting because I wanted my seal to be from mechanics rather than brute force, to be used over and over again.
When tank not in use, a simple plug almost finger tight is used.
This project would not be possible with out Dale's rack and I kept the damage slight, simple 1" hole and 4 bolt holes, the rack is built like the battle ship Texas, no damage done.
Our motorcycles have a evaporative emission system (?) You need need to valve out the vent line from main tank or otherwise you will draw gasoline from your vent line when using the auxilary tank. I believe a solenoid opens at start up and vacuum draws gas or vapors from this line. Honda Tee Honda 16960-ME9-000 - PIPE, THREE WAY JOINT : Babbitts Honda Partshouse is really a well built tee worth the money. BTW I tried to go over the top with this and believe it or not costs were not that bad
Tank = 190.00$ https://www.spunaluminumgastanks.com/
Fittings = 150.00$ http://www.summitracing.com/?
gclid=CJmynoyp4ccCFZKFaQod7xkM2w
