RandyM
DIY guy without a lot of electrical experience. 2014 NC700X. All accessory equipment removed, just stock hook up
After 12 hours of sitting idle the battery is dead. If left on a maintainer/ charger, starts right up. If I remove the negative cable and let sit for 12 hours, reinstall the negative cable it starts right up
Static voltage @13.4V after it's removed from the bike, charged and sitting for 24 hours. Running voltage (installed )@ 3000 RPM at 14.1 V
Bench tested/ analyzed the battery at two auto parts stores and 1 year old battery was good
Parasitic draw test with meter between neg cable (removed) and neg terminal post at .10 mV
Any ideas on next steps would be appreciated and thanks in advance for any help!
