FlaNC700X
- Joined
- Jul 28, 2012
- Messages
- 453
- Reaction score
- 1
- Points
- 0
- Location
- Sunny Ft.Lauderdale, Florida
Is there a bulb change out to increase the intensity to one of those HID bright bluish white lights?
....Center stand not available in US yet.
First what is the size of the bulb? Is it H4? Sorry my sercvice manual is still on order through my dealer!
Has anyone tried this PIAA bulb?PIAA 70456 Xtreme White Plus H4 Anti-vibration Bulb : Amazon.com : Automotive
Honda OEM bulbs may have a different alignment tab orientation from aftermarket H4/9003 bulbs. H4/9003 bulbs have the lower two tabs 120 degrees apart while the OEMs have tabs 90 degrees apart. If that is the case the lower tabs of aftermarket bulbs just need to be clipped off or carefully bent 90 degrees out of the way.
Thank you for the tips. I am leaning like ordering both of these from amazon and keep the one i like. I will keep the stock bulb stored in the rear tail for emergencies
In the ST forums there is a regular debate whether or not clipped-tab aftermarkets focus exactly like factory bulbs do. The bulbs have to meet stringent dimension requirements to be labeled as H4s or 9003s so the answer is yes.Now that you mention it, I remember that from my ST1100. This bulb indeed has the 90 degree lower pin orientation. Is the focus height the same?
Osram Bilux 94193 HD Germany 12v 60/55W H4U 37R E1 00801 w1B3
Is this a name for a bulb, or for a rocket to Mars? OMG!
I may go by and vibrate the box every now and then just to give it some use.
