GgarryP
As an engineer I doubt the frame is stiff enough to handle the eccentric loads from a single sided swing arm.
Sent from my VS995 using Tapatalk
there's twist in the swingarm itself but the swingarm is essentially statically determinate so it's reactions on the frame are independent of it's rigidity.On a single side swingarm, the axle is basically a lever that is trying to twist the swingarm. That ‘twist’ is transferred to the frame at the mounting points.
A double side swingarm, like what we have on the NC, does not twist because both sides of the axle are supported.
JT
Hey All,
Awhile back a user posted on the UK forum showing the Aluminum swing arm from a Honda NC750 Integra was a bolt on fit for the NC750x
So I asked around and figured it would work for my NC700x. I picked one up on ebay from Italy and just finally got it swapped. I'm not sure but I think this might be the only NC in the US with this swap.
It looks so much better than the original painted steel one and weighs about 7lbs less.
The only downside is that the chainguard or any combo rear fender chainguard has to be for this swing arm as the mounting points are different.
Sorry for the shitty picks I wanted to get some shots before the rain started. Plus I need to do a good clean from this winters riding.
I'm super happy with this upgrade
Now for a new exhaust, seat, and headlight assembly. Then I think I'll be done with it.
If you don't mind me asking (maybe dummy question), why you did it? What's the gain? Just because it looks better? 7 lbs lighter? What else?
The main reason I did it was because I hated the way it looked and when I saw how Wingriders looked with the better one I loved it.
I'm also not the type of person that will ever upgrade or buy another bike until this one is broken, stolen or not worth investing in. So making cosmetic changes that make the bike more of what I want are worth it to me.
