2023 Harley Davidson Fat Boy 114 [Specs, Features, Photos]
The 2023 Harley Davidson Fat Boy 114: More Is Better
It makes no sense to change what works, which is why the iconic Fat Boy is a staple of the Cruiser segment of the 2023 Harley Davidson lineup. What has been working is clearly power, style, and chrome!
Everything on this Harley Davidson is chromed, starting with the fork tubes and headlight nacelle and moving back over the tank console to the engine and exhaust. The 160mm front and 240mm rear solid disc Lakester wheels wrapped in fat rubber are the foundation of the Fat Boy’s recognizable steamroller posture.
The Milwaukee-Eight® 114 engine’s 119 lbs-ft of torque is ideal for any power-hungry lover of this American brand. The seat is deep and comfy. The floorboards are just right under your boots. Get ready to log some serious miles behind the bars of this iconic cruiser.
4 Color choices for the 2023 Harley Davidson Fat Boy 114: Vivid Black, Brilliant Billiard Blue, Gray Haze/Silver Fortune, and Heirloom Red Fade.
The 2023 Harley Davidson Fat Boy 114 starts at $20,199 USD / $25,499 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Harley Davidson Fat Boy 114 in one place.
2023 Harley Davidson Fat Boy 1142023 Harley Davidson Fat Boy 114
  • Price: $20,199 USD / $25,499 CAD
    • Milwaukee-Eight® 114 V-Twin engine
    • Solid Disc Lakester Wheels
    • Forward Controls
    • 160mm Front Tire, 240mm Rear Tire
  • Engine: 1,868cc V-twin
  • Power: 94 HP @ 4750 rpm (estimated)
  • Torque: 119 lbs-ft @ 3000 RPM
  • Wet Weight: 699 lbs (317 kg)
  • Seat Height: 25.9 inches (675 mm)
  • Suzuki Boulevard M109R B.O.S.S.
  • Indian Chief Bobber Dark Horse
  • Triumph Rocket 3 GT
  • Ducati Diavel V4
2023 Harley Davidson Fat Boy 114 Specifications​
Engine1,868cc V-twin, Milwaukee-Eight® 114
Engine Torque94 HP (estimated)
Bore x Stroke4.016 in. x 4.5 in.
Compression Ratio
10.5:1
Exhaust2-into-2 staggered; catalyst in muffler
Clutch
Transmission6-speed
Primary Drive
Gear, 34/46 ratio
Front Fork
Dual-bending valve 49 mm telescopic with aluminum fork triple clamps; dual rate spring; “beer can” covers
Rear Fork
Hidden, free piston, coil-over monoshock; 43mm stroke; toolless hydraulic preload adjustment
Wheels, Front Type
Machined, Lakester cast aluminum
Wheels, Rear Type
Brakes Front
4-piston fixed front
Brakes Rear2-piston floating rear
Tires Front
160/60R18,70V,BW
Tires Rear
240/40R18,79V,BW
Fuel Tank Capacity5 gal.
ColorBright Billiard Blue, Vivid black,Gray Haze, Heirloom Red Fade
Ignition
HeadlightAll LED headlamp
Length
93.3 in.
Trail
4.1 in.
Rake30
Wheelbase
65.6 in.
Ground Clearance
4.5 in.
Seat Height
25.9 in.
Weight, As Shipped
671 lb.
Warranty
2023 Harley Davidson Fat Boy 114 Features​
BRIGHT CHROME FINISHES​
A healthy serving of sculpted bright chrome gives the Fat Boy motorcycle a look that’ll make a big impact.
STEAMROLLER STANCE​
A muscular look thanks to solid-disc Lakester wheels wrapped in the widest front tire we’ve ever offered from the factory at 160mm combined with a rear tire at 240mm.
SIGNATURE LED FORWARD LIGHTING​
Darkness-defying lighting that gives you great nighttime visibility.
HIGH PERFORMANCE REAR MONO SHOCK​
Easily adjustable mono-shock rear suspension allows for dynamic cornering while preserving the hardtail look.
2023 Harley Davidson Fat Boy 114 Photos​
2023 Harley Davidson Fat Boy 114 2023 Harley Davidson Fat Boy 114 2023 Harley Davidson Fat Boy 114 2023 Harley Davidson Fat Boy 114
2023 Harley Davidson Fat Boy 114 Videos​
2023 Harley Davidson Fat Boy 114 First Ride | REVIEW:
I Bought a New 2023 Fat Boy Harley Davidson Motorcycle!
The post 2023 Harley Davidson Fat Boy 114 [Specs, Features, Photos] appeared first on webBikeWorld.
