2023 Ducati Hypermotard 950/RVE/SP [Specs, Features, Photos]
The 2023 Ducati Hypermotard Keeps The Thrills Coming
What happens when a dirt bike and a Panigale have a baby? You get a Hypermotard! Ducat’s line of Italian-bred supermotos is a bit of an oddball among the Bologna-based manufacturer’s lineup, it trades luxury comforts and sleek lines for rugged performance that is equally as at home on dirt or tarmac. The 2023 iteration of this bike didn’t receive any updates over last year, but the package remains a standout among the competition.
The 2023 Ducati Hypermotard harnesses a version of the 11-degree Testeretta two-cylinder engine – the same platform that can be found across the Ducati lineup, including in the Monster and the SuperSport. The engine cranks out a perfectly respectable 114 hp and 71 lb-ft of torque.
Ducati offers the Hypermotard in three unique packages – the basic 950, the RVE, and the SP. Each package is fundamentally similar, while the RVE and SP add some unique goodies. While the standard model comes from the factory equipped with features like daytime running lights, a dual direction quick-shifter, and a Bosch Intertial measurement unit, the SP model also gets Marchesni forged wheels, some carbon fibre bits, and Ohlins front and rear suspension. As a result of the upgraded suspension and carbon fibre, the SP sits a little higher and weighs about 4 lbs less. The RVE package is a limited edition version of the standard bike which features a graffiti-styled livery and is limited to just 100 bikes.
The 2023 Ducati Hypermotard 950 starts at $14,995 USD/ $17,395 CAD
The 2023 Ducati Hypermotard 950 RVE starts at $16,095 and is not currently available in the current market.
The 2023 Ducati Hypermotard 950SP starts at $18,695 USD/ $21,295 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc., so you can read up on the new 2023 Ducati Hypermotard 950/RVE/SP in one place.
2023 Ducati Hypermotard 950/RVE/SP2023 Ducati Hypermotard 950/RVE/SP
  • Price: $14,995 USD/ $17,395 CAD
    • 11 degree Testeretta engine
    • Available Limited Edition RVE model
    • Six Axis Inertial Measurement Unit
    • Optional Ohlins Suspension
  • Engine: 937cc V-Twin
  • Power: 114 hp
  • Torque: 71 lb-ft
  • Weight: 392 lbs (178 kg)
  • Seat Height: 34.2 inches (870 mm)
  • KTM 690 SMC R
  • Husqvarna 701 Supermoto
2023 Ducati Hypermotard 950/RVE/SP Specifications​
Engine937cc, Testastretta 11°, L-Twin cylinder, 4 valve per cylinder, Desmodromic, liquid cooled, magnesium head covers
Power84 kW (114 hp) @ 9,000 rpm
Bore x Stroke94 x 67.5 mm
Compression Ratio13.3:1
Fuel InjectionElectronic fuel injection system, Ø 53 mm throttle bodies with Ride-by-Wire system
ExhaustDouble under-tail aluminum muffler; catalytic converter and two lambda probes.
Torque96 Nm (71 lb-ft) @ 7,250 rpm
ClutchSlipper and self-servo wet multiplate clutch, hydraulic control
Transmission6 speed with Ducati Quick Shift up/down
Final DriveChain; Front sprocket 15; Rear sprocket 43
Suspension FrontÖhlins fully adjustable, upside-down Ø 48 mm
Suspension RearProgressive linkage with fully adjustable Öhlins monoshock. Aluminium single-sided swingarm
Brakes Front2 x 320 mm semi-floating aluminum flange discs, radially mounted Monobloc Brembo callipers, 4-piston 2-pad, radial pump with adjustable lever, with Bosch Cornering ABS
Brakes Rear245 mm disc, 2-piston calliper, with Bosch Cornering ABS
Tires FrontPirelli Diablo Supercorsa SP, 120/70 ZR17
Tires RearPirelli Diablo Supercorsa SP, 180/55 ZR17
Fuel Tank Capacity14.5 l (3.8 US gal)
Color
Ignition
HeadlightLED
Max Length
Max Width
Max height
Wheelbase1,498 mm (59.0 in)
Rake25°
Trail104 mm (4.1 in)
Seat Height890 mm (35.0 in)
Dry Weight176 kg (388 lb)
Warranty24 months, Unlimited mileage
2023 Ducati Hypermotard 950/RVE/SP Features​
SUSPENSION​
The Hypermotard 950 SP is equipped with a fully adjustable 48 mm Öhlins fork with 185 mm wheel travel and a fully adjustable Öhlins shock absorber with 175 mm wheel travel.
SADDLE​
The saddle on the SP version is flat, motard style, to further facilitate longitudinal movement while riding.
WHEELS​
Hypermotard 950 SP is fitted with lightweight Marchesini forged rims with 3 Y-spokes, 3.5″ section up front and 5.5″ at the rear, and Pirelli Diablo Supercorsa SP tyres, size 120/70 ZR7 up front and 180/55 ZR177 at the rear.
2023 Ducati Hypermotard 950/RVE/SP Photos​
2023 Ducati Hypermotard 950/RVE/SP 2023 Ducati Hypermotard 950/RVE/SP 2023 Ducati Hypermotard 950/RVE/SP 2023 Ducati Hypermotard 950/RVE/SP
2023 Ducati Hypermotard 950/RVE/SP Videos​
Ducati Hypermotard 950 by EnglishBikerDan:
12 Month Review on my 2022 Ducati HyperMotard 950 SP by HyperMotardKing:
The post 2023 Ducati Hypermotard 950/RVE/SP [Specs, Features, Photos] appeared first on webBikeWorld.
