2023 BMW R 1250 GS / GS Adventure [Specs, Features, Photos]
The 2023 BMW R 1250 GS Continues To Impress Adventure Riders
The 2023 BMW R 1250 GS has been an icon for decades, and it continues to inspire with new features. Whether on or off road, the riding dynamics and mix of top of the line hardware and electronics makes this a do it all machine you can depend on. BMW continues to lead the European brands in this category. Much like the other 2023 BMW models they have continued to evolve and improve.
While the 1250’s engine didn’t need any changes this year, the tech package has been upgraded to include such features as full color TFT display, adaptive LED headlights, seat heating and.
Concentrating on the handling you’ll find the Telever front and paralever rear to do an admirable job of keeping things in order whether on or off road. Multiple riding modes ensure that you can master any driving situation with confidence. Whether you’re on an extended tour or off-road, the BMW R 1250 GS with its boxer engine is the perfect choice for anyone who wants BMW’s perfect blend of driving dynamics and comfort.
The GS model caters more to on-pavement and light offroad while the Adventure model is the the serious off-road enthusiasts.
The 2023 BMW R 1250 GS starts at $17,995 USD/$21,795 CAD for the base model and goes up depending on trim levels such as Adventure which starts at $20,345 USD/$24,145 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 BMW R 1250 GS in one place.
  • Price: $17,995 USD / $21,795 USD
    • BMW Telelever and Paralever Suspension
    • Comprehensive electronics and color TFT display
    • Dynamic Suspension adjustment
    • Multiple ride modes
  • Engine: 1254cc air/liquid-cooled four stroke flat twin
  • Power: 136 horsepower
  • Torque: 105 lb-ft
  • Weight: 549 lbs (249 kgs)
  • Seat Height: 33.5 inches (850 mm)
2023 BMW R 1250 GS / GS Adventure Specifications​
Engine1254cc, Air/liquid-cooled four stroke flat twin engine, double overhead camshaft, one balance shaft and variable engine timing system BMW ShiftCam.
Engine Power136 HP at 7,750 rpm
Bore x Stroke102.5 mm x 76 mm
Compression Ratio12.5 : 1
Fuel deliveryElectronic intake manifold injection
Max Torque105 lb-ft at 6,250 rpm
ClutchWet clutch with an anti-hopping function, hydraulic activation
TransmissionConstant mesh 6-speed gearbox with helical gear teeth
DriveShaft Drive
Suspension FrontBMW Motorrad Telelever; stanchion diameter 1.5″ (37 mm), central spring strut
Suspension RearCast aluminium single-sided swing arm with BMW Motorrad Paralever; WAD strut (travel-related damping), spring pre-load hydraulically adjustable (continuously variable) at handwheel, rebound damping adjustable at handwheel
Brakes FrontDual disc brake, floating brake discs, diameter 12.0″ (305 mm), 4-piston radial calipers
Brakes RearSingle disc brake, diameter 10.9″ (276 mm), double-piston floating caliper
Tires Front120/70 R 19
Tires Rear170/60 R 17
Fuel Tank Capacity5.2 gallons
Color
AlternatorThree-phase generator with 510 Watt nominal power
Battery12 V / 11.8 Ah
HeadlightFull-LED headlight
Tail Light
Overall Length86.9″ (2,207 mm)
Overall Width37.5″ (952.5 mm)
Overall Height56.3″ (1,430 mm)
Wheelbase59.6″ (1,514 mm)
Castor4.0″ (100.6 mm)
Seat Height33.5″ / 34.3″ (850 mm / 870 mm)
(OE lowered suspension 31.5″ / 32.3″ – 800 mm / 820 mm)
Unladen weight, road ready, fully fueled
549 lbs (249 kg)
Warranty
2023 BMW R 1250 GS / GS Adventure Features​
LED flashing turn indicators as standard with optional Cruising Light​
Increase visibility thanks to their strong luminosity. The Cruising Light keeps the front indicators constantly dimmed and ensures a striking appearance, especially at night and in poor visibility. (European model shown).
Handlebar risers of 30 mm​
Ensure a relaxed posture and give you much more control when riding standing up.
Enduro package for trips off-road​
Less road, more fun: Engine protection bar, sports suspension, handlebar risers and off-road tires invite you to explore routes way off the beaten track.
Comfortable heated seat​
Easily adjustable to several levels, it provides you and your passenger with comfortable warmth in low temperatures and on long tours.
Due to the on-going supply situation, optional heated seats, as shown, are not currently available for this model
Adaptive headlight with LED headlight​
Enables the best possible illumination of the inner curve area.
Ride Modes Pro and ECO Modes​
Fun at the touch of a button: The Ride Modes Pro are adapted to different riding styles and give you even more control over your bike with features such as the new dynamic engine brake control. The new ECO Mode in series gets the most out of every full fuel tank.
DTC and ABS Pro in series​
Enable precise handling in every riding situation: ABS Pro stabilizes the bike when braking in a heel angle. DTC prevents the rear wheel from spinning on surfaces with little grip.
2023 BMW R 1250 GS / GS Adventure Photos​
2023 BMW R 1250 GS / GS Adventure Videos​
2023 BMW R 1250 GS Trophy:
2023 Bmw R 1250 GS Trophy & Adventure:
BMW Official Websites​
The post 2023 BMW R 1250 GS / GS Adventure [Specs, Features, Photos] appeared first on webBikeWorld.
