2022 Triumph Tiger 1200 GT [Specs, Features, Photos]
The 2022 Triumph Tiger 1200 GT: Cross Country Touring At its Best​
Triumph recently updated its Tiger 1200 models. Like the smaller Tiger 900 siblings, there will be two model ranges — the Tiger 1200 GT models and the Tiger 1200 Rally models — as part of the 2022 Triumph motorcycle portfolio. The Tiger 1200 GT is available in three variants — the base GT, a mid-level GT Pro, and a range-topping GT Explorer version.
The British manufacturer has made some rather significant updates to its flagship adventure motorcycle for 2022. The bikes are powered by an updated 1,160cc three-cylinder engine that produces 147 hp and 95 lb-ft of torque. The engine includes a new T-plane firing order for better low down tractability and responsiveness and a more engaging mid-range and top-end.
The Tiger 1200 G models feature an all-new chassis and redesigned swingarm lighter than before. Electronically-controlled Showa semi-active hardware handles suspension, allowing riders to adjust damping and electronically set spring preload. The bikes feature a 19-inch front and 18-inch rear wheel setup with Metzeler Tourance tires.
While all three variants have pretty impressive features, the base GT model misses some tech, like lean-sensitive cornering lights, a bidirectional quickshifter, hill hold, cruise control, and heated grips. It also gets only three riding modes — Rain, Road, and Sport — while the GT Pro and GT Explorer offer five — Road, Rain, Sport, Rider-configurable, and Off-Road.
The Tiger 1200 GT Explorer also gets a larger fuel tank (7.92 US gal compared to the GT Pro’s 5.28 US gal unit), a tire pressure monitoring system, and heated rider and pillion seats. It also features a rear-facing radar system that offers a blind spot and lane change warning system.
The 2022 Triumph Tiger 1200 GT starts at $19,100 USD / $22,300 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Triumph Tiger 1200 GT, GT Pro, and GT Explorer in one place.
  • Price: $19,100 USD / $22,300 CAD
    • New 1160cc triple engine, designed to set a new benchmark for engine character
    • All-new lightweight chassis and class-leading equipment
    • More than 25kg lighter than the previous generation
    • 50+ Genuine Triumph Accessories
Main Specs​
  • Engine: 1,160cc inline-triple
  • Power: 147 hp
  • Torque: 95 lb-ft
  • Wet Weight: 529 lbs (GT)
  • Seat Height: Adjustable 33.46 inches /34.52 inches
Competitors​
2022 Triumph Tiger 1200 GT Specifications​
Engine1160cc, Liquid-cooled, 12 valve, DOHC, inline 3-cylinder
Power148bhp
Bore x Stroke3.54″ X 2.38″
Compression Ratio13.2:1
Fuel SystemMultipoint sequential electronic fuel injection with electronic throttle control
ExhaustStainless steel 3 into 1 header system with underslung primary silencer and side mounted secondary silencer
ClutchHydraulic, wet, multi-plate, slip and assist
Transmission6-Speed
Final DriveShaft drive
Suspension FrontShowa 49mm, semi-active damping USD forks. 7.87″ travel.
Suspension RearShowa semi-active damping monoshock, with automatic electronic preload adjustment. 7.87″ wheel travel.
Brakes FrontBrembo M4.30 Stylema monoblock radial calipers, OC-ABS, twin 320mm floating discs. Magura HC1 span adjustable radial master cylinder with separate reservoir.
Brakes RearBrembo single piston caliper, OC-ABS, single 282mm disc. Rear master cylinder with remote reservoir.
Tires FrontMetzeler Tourance, 120/70R19 (M/C 60V TL)
Tires Rear
Metzeler Tourance, 150/70R18 (M/C 70V TL)
Fuel Tank Capacity5.28 Us Gal
Color
Ignition
HeadlightLED
Overall Length
Width HandlebarsHandlebars 33.42″, Handguards 38.66″
Height Without MirrorLow screen 56.53″, high screen 58.93″
Wheelbase61.41″
Trail4.72″
Seat HeightAdjustable 33.46/34.52″
Wet Weight529lbs
Warranty
2022 Triumph Tiger 1200 GT Features​
ALL-NEW ENGINE​
The unique, lightweight, new 1160cc T-Plane triple engine has been optimized for capability, character and performance.
WEIGHT​
The first task was to significantly reduce weight without sacrificing the Tigers’ planted feel and well-earned reputation for comfort.
DESIGN​
Each Tiger 1200 has been designed to feel as good on the last mile of your adventure as it did on the first.
CAPABILITY​
Exploring the unknown is what adventure riders dream about. The adrenaline of discovery, the rush of riding in new landscapes.
RIDER-FOCUSED TECHNOLOGY​
The latest technology has been incorporated seamlessly into the new Tiger line-up to help you ride further, for longer, more safely and in total comfort.
INCREDIBLE STYLE​
The Tiger 1200’s rugged good looks, poise and attitude is so much more than the result of an exercise in aesthetics.
2022 Triumph Tiger 1200 GT Photos​
2022 Triumph Tiger 1200 GT 2022 Triumph Tiger 1200 GT 2022 Triumph Tiger 1200 GT 2022 Triumph Tiger 1200 GT
2022 Triumph Tiger 1200 GT Videos​
2022 Triumph Tiger 1200 Official Promo:
2022 Triumph Tiger 1200 vs BMW R 1250 GS by 1000PS Motorcycle Channel
The post 2022 Triumph Tiger 1200 GT [Specs, Features, Photos] appeared first on webBikeWorld.
