2022 Triumph Street Scrambler: A Modern Classic Fit for the Urban Jungle and Light Trails
The 2022 Triumph Street Scrambler is a modern classic inspired by the desert racers of yesteryear. It sits alongside the Street Twin in the 2022 Triumph Motorcycles lineup and has some features that make it capable enough for light off-roading. Like most Triumph motorcycles, the Street Scrambler fuses old-school-cool heritage with modern capability for an unmistakable ride experience.
Powering the Street Scrambler is Triumph’s high-torque 900cc parallel-twin producing 64.1 hp and 59 lb-ft of peak torque. The engine is mated to a 5-speed gearbox.
Typically, modern classics are void of a lot of the electronic wizardry we see on many of today’s motorcycles. Still, the British manufacturer has equipped the Street Scrambler with a decent amount of tech. There are three riding modes on offer — Road, Rain, and Off-Road — that alter the level of intervention from the ABS and traction control.
The Street Scrambler comes with a Digi-analog instrument cluster — the speedometer is an analog unit, but other helpful information like range and the odometer are digital. The bike features conventionally upright KYB front forks and twin shock absorbers at the rear. This isn’t a hardcore off-road motorcycle, and there’s a respectable 120mm of suspension travel at either end.
For 2022, Triumph has added a host of intricate new details, including a side panel with an aluminum number board, new headlight brackets, and a different throttle body finish.
The 2022 Triumph Street Scrambler starts at $11,295 USD / $12,845 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Triumph Street Scrambler in one place.
- Price: $11,295 USD / $12,845 CAD
- Peak torque of 59 lb-ft at a low 3,250rpm
- Three riding modes (Road, Rain, and Off-Road)
- Dual-purpose Metzeler Tourance tires
- New detailing elements for 2022
- Engine: 900cc parallel-twin
- Power: 64.1 hp
- Torque: 59 lb-ft
- Wet Weight: 492 lbs (223 kg)
- Seat Height: 31.1 inches (790 mm)
2022 Triumph Street Scrambler Specifications
Engine | 900cc, Liquid cooled, 8 valve, SOHC, 270° crank angle parallel twin |
Power | 64.1 bhp |
Bore x Stroke | 84.6 X 80 |
Compression Ratio | 11.0:1 |
Fuel System | Multipoint sequential electronic fuel injection |
Exhaust | Brushed stainless steel 2 into 2 exhaust system with twin high-level brushed stainless steel silencers |
Clutch | Wet, multi-plate torque assist clutch |
Transmission | 5-Speed |
Final Drive | O ring chain |
Suspension Front | Ø 41mm forks with cartridge damping. 120mm travel |
Suspension Rear | Twin shocks with adjustable preload. 120mm rear wheel travel |
Brakes Front | Single Ø310mm floating disc, Brembo 4-piston fixed axial caliper, ABS |
Brakes Rear | Single Ø255mm disc, Nissin 2-piston floating caliper, ABS |
Tires Front | 100/90-19 Metzeler Tourance |
Tires Rear | 150/70 R17 Metzeler Tourance |
Fuel Tank Capacity | 3.17 gal (12 L) |
Color | |
Ignition | |
Headlight | LED |
Tail Light | LED |
Overall Length | |
Width Handlebars | 835 |
Height Without Mirror | 46.5” (1180mm) |
Wheelbase | 56.9” (1445mm) |
Trail | 109 |
Seat Height | 31.1” (790mm) |
Wet Weight | 492 lbs (223 kg) |
Warranty | |
Extension |
2022 Triumph Street Scrambler Features
STYLE
Part of the iconic Bonneville family, the New Street Scrambler features an authentic scrambler silhouette with clean lines and minimal bodywork. It has beautifully evolved, incorporating incorporating modern finishes with even more premium custom style and detailing.There are three contemporary new paint schemes – choose from single color Jet Black or Urban Grey, or the dual Matte Khaki and Matte Ironstone option. Premium touches include a new side panel with aluminum number board featuring an embossed Street Scrambler logo for a distinctive new rugged scrambler style, new throttle body finishers and new brushed aluminum headlight brackets, enhancing the stripped-back custom scrambler styling.
PERFORMANCE
The 900cc high-torque engine offers thrilling torque-rich Bonneville performance, with 64 HP of peak power at 7,250rpm and 59 LB-FT peak torque at 3,250rpm. It delivers thrilling power and torque across the rev range for strong acceleration exactly when you need it.The liquid-cooled, latest generation Bonneville twin cylinder engine retains its power, character and responsiveness and is now cleaner and more efficient, with lower emissions and excellent fuel efficiency.
You also get the exciting scrambler soundtrack you’d expect – the compact high-level exhaust system delivers a unique scrambler exhaust note that matches its distinctive character, combined with the unmistakable sound of a British twin.
CAPABILITY
The high specification Brembo 4-piston front brake caliper provides excellent stopping power with great bite and feel, providing better rider control. The long travel cartridge front forks are finished with traditional rubber gaiters while the preload adjustable twin shocks feature grey springs and black shrouds and deliver 4.7 inches rear wheel travel for a comfortable ride on any terrain.Ride by wire throttle control ensures a responsive feel and provides great rideability, safety and control from a single throttle body. These features combine to give intuitive confidence-inspiring handling and underline the Street Scrambler’s dual capabilities.
Ergonomics and Handling
Improved rider ergonomics ensure that the Street Scrambler is accessible for every rider. The dedicated chassis setup provides a unique frame, wide aluminum handlebars and mid-position pegs. Combined with long travel front and rear suspension and a large 19” front wheel, it delivers a commanding riding position for urban roads plus greater capability on unsurfaced roads and trails. Comfortable “standover” ergonomics allow for feet flat on the floor maneuverability, providing confidence-inspiring handling and everyday comfort, while the accessible low seat height allows maximum confidence and control for all riders.Accessible and Fun
The New Street Scrambler also comes with a 2-year, unlimited mileage warranty and a high 10,000 mile service interval.Technology
Advanced rider-focused technology ensures you can optimize your ride to suit your needs. Choose from three riding modes – road, rain or off-road – accessed via the mode selection button in the left hand switch cube. Road and rain modes adjust throttle map and traction control while off-road mode turns off ABS and traction control to give you better feel on loose surfaces.Switchable ABS and switchable traction control are fitted as standard, to manage torque when traction is compromised, reflecting the bike’s dual-purpose capability. The torque-assist clutch is optimized for light and easy operation for more comfort over long journeys and in heavy traffic.
There’s also a distinctive and power efficient LED rear light, key fob incorporated immobilizer, and a USB charging socket located under the seat for convenient gadget charging.
2022 Triumph Street Scrambler Photos
2021 Triumph Tiger 1200 XR Videos
New Street Scrambler Features and Benefits Official Video:
Triumph Street Scrambler Comprehensive Review by Yammie Noob:
The post 2022 Triumph Street Scrambler [Specs, Features, Photos] appeared first on webBikeWorld.
