2022 Triumph Bonneville Bobber [Specs, Features, Photos]
The 2022 Triumph Bonneville Bobber Looks as Good as It Goes​
The Triumph Bonneville Bobber is one of the most attractive and unique-looking motorcycles in the 2022 Triumph line-up, with a unique and instantly recognizable silhouette primarily inspired by the bobber movement of the 1940s. The British manufacturer has nailed the styling with unmistakable ‘bobber’ elements, including a ‘floating’ adjustable single-seat, classic-looking headlamp, chunky tires, and a flat, wide handlebar.
Powered by the 1,200cc, parallel-twin engine that also features on multiple other Bonneville models, this Triumph bike has the performance to complement its looks. Peak output figures are 76.9 hp and 78.2 lb-ft of torque, and Triumph has said it tuned the engine for a more responsive and linear torque curve.
While it may not have the most comprehensive list of electronic rider aids, the essentials are in order with ABS and switchable traction control. Two riding modes on offer— Road and Rain — alter traction control intervention and throttle response.
For 2022, the Bonneville Bobber is available in three color options — Matt Storm Gray and Matt Ironstone, Cordovan Red, and Jet Black. Triumph has also released a special ‘Gold Line’ edition of the motorcycle that features hand-painted detailing on a Carnival Red and Sapphire Black paint scheme.
The 2022 Triumph Bonneville Bobber starts at $13,495 USD / $15,395 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Triumph Bonneville Bobber in one place.
  • Price: $13,495 USD / $15,395 CAD
    • 1,200cc High-Torque parallel-twin engine
    • Ride-by-wire throttle with two riding modes
    • Minimalist styling and muscular presence
Main Specs​
  • Engine: 1,200cc parallel-twin
  • Power: 76.9 hp
  • Torque: 78.2 lb-ft
  • Wet Weight: 553 lb (251 kg)
  • Seat Height: 27.2-27.6 in (690-700 mm)
Competitors​
2022 Triumph Bonneville Bobber Specifications​
Engine1200cc, Liquid cooled, 8 valve, SOHC, 270° crank angle parallel twin
Power76.9 HP @ 6100 RPM
Bore x Stroke97.6 X 80
Compression Ratio10.0:1
Fuel SystemMultipoint sequential electronic fuel injection
ExhaustBrushed stainless steel 2 into 2 twin-skin exhaust system with brushed stainless silencers
ClutchWet, multi-plate torque assist clutch
Transmission6-Speed
Final DriveChain
Suspension FrontØ 47 mm Showa cartridge forks
Suspension RearMono-shock RSU with linkage
Brakes FrontTwin Ø310mm disc, Brembo 2-piston sliding axial calipers
Brakes RearSingle Ø255mm disc, Nissin single piston sliding axial caliper
Tires FrontMT90B16
Tires Rear
150/80 R16
Fuel Tank Capacity3.2 US gal (12 litres)
Color
Ignition
HeadlightLED
Overall Length
Width Handlebars31.5 in (800 mm)
Height Without Mirror40.3 – 41.5 in (1024 – 1055 mm)
Wheelbase59.1 in (1500 mm)
Trail3.6 in (92.0 mm)
Seat Height27.2 – 27.6 in (690 – 700 mm)
Wet Weight553 lb (251 kg)
Warranty
2022 Triumph Bonneville Bobber Features​
MADE TO STAND OUT​
As you approach, it’s impossible not to notice the Bobber and fall in love with its character and charm. Every inch of detail was refined, deliberated over, and crafted for a flawless finish and imposing style. An aggressive attitude, with more than a touch of elegance comes easy with the Bobber. The original Bobber evolved, keeping the classic lines and premium feel but adding an even more moody attitude, blacked-out styling and muscular poise. A more muscular front end, larger forks and bigger tires combine with the discreetly hidden monoshock rear suspension and ergonomically designed floating aluminum seat to bring unparalleled capability and comfort while maintaining the timeless Bobber heritage. Poised and imposing with an elegant beauty that is everything this iconic classic represents, it’s easy to see why the Bobber was Triumph’s fastest selling motorcycle ever.
A pure, brutal beauty with an unparalleled heritage and category-defining capability, this is a head-turning, handcrafted factory custom with a truly iconic silhouette that is instantly recognizable out on the street. Real style is not just about standing out, but being remembered.
BUILT TO RIDE AS BEAUTIFULLY AS IT LOOKS​
Riding is about the rush of emotions and connections it brings, feeling the motorcycle beneath you as you enjoy your freedom. The Bobber amplifies your riding pleasure in every dimension with its enhanced performance, muscular poise and higher specification of suspension, brakes and ride enhancing technology. The beating heart of the Bobber is the newly updated high-torque Bonneville 1200cc engine that delivers 76 HP peak power and a dedicated soundtrack that surrounds you as you ride, courtesy of its innovative twin airbox and slash cut silencers. Torque rich effortless acceleration is a hallmark of this critically acclaimed British parallel twin engine enhanced for 2021 to be even more responsive, with a high 78 LB-FT of peak torque, dialed in to deliver low down and all the way up through the mid-range, just where you want it most.
BEAUTIFULLY INTEGRATED TECHNOLOGY AND MODERN CAPABILITY​
The Bobber’s style and heritage is exquisite, and this is matched by the seamless way that its truly modern performance, capability and rider technology is woven into the bike, without compromise to its strong iconic styling and clean lines. From its hidden shock to its innovative swinging cage, for that distinctive ‘hard tail’ look, to its adjustable seat, riding modes, higher specification Brembo front brakes and Showa cartridge forks, the Bobber comes with all of the quality that lives up to its class-leading reputation.
Whether you’re cruising around town, nipping through traffic, sweeping through the country roads or just enjoying the views, the Bobber’s rider-focused technology will be right there with you. With Road and Rain riding modes, adjustable traction control, torque-assist clutch, ABS, and a easy single button cruise control the Bobber sets a standard – all there for the perfect ride and all seamlessly integrated into the authentic Bobber lines.
BORN FOR CUSTOMIZATION​
Designed with an uncompromising attention to detail, the Bonneville Bobber is the perfect canvas for your attitude and personal style. Created with a pure stripped down, aggressive Bobber stance, this is just the start of your custom design. With over 75 Bobber accessories on hand, from detailing and design features, to comfort and luggage, it’s your choice as to how you build your perfect Bobber, to reflect your personality and riding style. Select your own accessories from our easy to use online configurator to get your Bobber custom off to an instant start.
Add your own touch, your personality. Make it yours.
2022 Triumph Bonneville Bobber Photos​
2022 Triumph Bonneville Bobber 2022 Triumph Bonneville Bobber 2022 Triumph Bonneville Bobber 2022 Triumph Bonneville Bobber
2022 Triumph Scrambler 1200 XC/XE Videos​
Triumph Bonneville Bobber Official Video:
Triumph Bobber vs Triumph Speedmaster: Which One Should You Buy? by MOTOBOB:
The post 2022 Triumph Bonneville Bobber [Specs, Features, Photos] appeared first on webBikeWorld.
