The Boulevard C50/C50T Is the Entry into Suzuki’s Cruiser Lineup for 2022
The Suzuki Boulevard C50 and C50T are classic, old-school cruisers that act as the entry into their cruiser lineup for 2022. Both motorcycles are effectively the same, and the only differentiating factor is that the C50T comes with some touring-oriented comforts like a windscreen and saddlebags.
The Boulevard C50 and C50T are powered by a liquid-cooled, 805cc, 45˚ V-twin engine producing around 53hp and 52 lb-ft of torque. The Japanese manufacturer mentions that this engine has been tuned for most of its torque to be available at lower in the rev band — typical of what you’d expect from a low-slung cruiser.
As we mentioned above, the C50T features some additional equipment over the base model. As a result, it weighs 33 lbs more than the C50 at 644 lbs (292kg). Evidently, this isn’t a light motorcycle, but a super-low seat height of 700mm should allow most riders to get their feet on the ground comfortably.
For 2022, the Boulevard C50 is available in two color options: Candy Daring Red or Solid Iron Gray. The C50T is available exclusively in Suzuki’s Pearl Brilliant White color scheme. In Canada, the Boulevard is also available in a C50SE version for 2022. The ‘SE’, which presumably stands for ‘Special Edition’, slots itself between the base C50 and the top of the line C50T. It comes with a windshield and saddlebags but misses out on the textured seat and tank badging from the C50T.
The 2022 Suzuki Boulevard C50/C50T starts at $8,609 USD / $10,499 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Suzuki Boulevard C50/C50T in one place.
Motorcycle Overview
- Price: $8,609 USD / $10,499 CAD
- Torquey 805cc, fuel-injected, liquid-cooled, V-twin engine
- Buckhorn-style handlebars for commanding riding position
- Brushed stainless steel components
- Engine: 805cc V-twin
- Power: 53hp
- Torque: 52lb-ft
- Wet Weight: 611 lbs (277kg)
- Seat Height: 27.6 inches (700mm)
- Indian Scout Sixty
- Kawasaki Vulcan 900
- Honda Shadow Aero
2022 Suzuki Boulevard C50/C50T Specifications
Engine | |
Engine | 805cc, 4-stroke, liquid-cooled, SOHC, 45˚, V-twin |
Bore x Stroke | 83.0 mm x 74.4 mm (3.268 in. x 2.929 in.) |
Compression Ratio | 9.4:1 |
Fuel System | Suzuki fuel injection with SDTV |
Lubrication | Wet sump |
Drivetrain | |
Transmission | 5-speed constant mesh |
Clutch | Wet, multi-plate type |
Final Drive | Shaft drive |
Chassis | |
Suspension Front | Telescopic, coil spring, oil damped |
Suspension Rear | Link style, solo shock, coil spring, oil damped |
Brakes Front | Disc brake |
Brakes Rear | Drum brake |
Tires Front | 130/90-16 M/C (67H), tube type |
Tires Rear | 170/80-15 M/C (77H), tube type |
Fuel Tank Capacity | 15.5 L (4.1 US gal.) |
Color | Candy Daring Red or Solid Iron Gray |
Electrical | |
Ignition | Electronic ignition (transistorized) |
Spark Plug | NGK DR7EA or DENSO XX22ESR-U |
Headlight | 12V 60/55W H4 |
Tail Light | LED |
Dimensions | |
Overall Length | 2,500 mm (98.4 in.) |
Overall Width | 955 mm (37.6 in.) |
Overall Height | 1,110 mm (43.7 in.) |
Ground Clearance | 140 mm (5.5 in.) |
Wheelbase | 1,655 mm (65.2 in.) |
Seat Height | 700 mm (27.6 in.) |
Curb Weight | 277 kg (611 lb.) |
Warranty | |
Warranty | 12-month unlimited mileage limited warranty |
Extension | Longer coverage periods with other benefits available through Suzuki Extended Protection (SEP) |
2022 Suzuki Boulevard C50/C50T Features
Key Features
Candy Daring Red or Solid Iron Gray paint with understated tank graphics augment the Boulevard’s classic posture.
Fifty cubic inch (805cc), 45-degree V-twin engine rumbles through dual pipes as it smoothly puts down power that’s at home in town or out on the highway.
With a light pull, the clutch feeds engine power to the smooth-shifting five-speed transmission and out to the clean shaft drive.
Riders settle in behind wide, buckhorn-style handlebars, with feet comfortably on forward-mount floorboards, while sitting on a plush seat that’s a short 27.6 inches above the ground.
The classically styled 4.1-gallon fuel tank complements the large, valance fenders that hover over the wide 15-inch rear and 16-inch front tires mounted on spoke-style chrome wheels.
Brushed, stainless steel covers shield the stout front fork, whereas a hidden, link-style rear shock smooths the ride while giving the bike an old-school, hard-tail look.
Beefy tires on wide, spoke-style chrome wheels bring a nostalgic look while delivering modern performance.
Engine Features
Narrow, 805cc, fuel-injected, liquid-cooled, SOHC, four-valve-per-cylinder, 45-degree, V-twin engine is tuned for exceptional low rpm torque.
Sculpted engine features polished aluminum and chrome covers that complement the visually striking cylinders with symmetrical cooling fins.
Offset crankpins bring optimally balanced firing intervals and create a signature V-twin rumble.
Suzuki Dual Throttle Valve (SDTV) electronic fuel-injection system maintains optimum air velocity in the intake tract for smooth low- to mid-rpm throttle response.
Auto Fast Idle System (AFIS) automatically sets the throttle-valve opening during cold engine starts by monitoring coolant temperature.
Cutting-edge 3D-mapped digital ignition system using a throttle-position sensor helps boost the hallmark big V-twin low-down torque.
Chromed and staggered dual exhaust system mounted on the right side of the engine is tuned for responsive torque delivery, providing a deep, rumbling exhaust note.
A wide-ratio five-speed transmission features a high fifth-gear ratio for relaxed highway cruising.
Low-maintenance shaft drive is clean-running and has minimal torque reaction as it efficiently transmits power to the wide 15-inch rear tire.
Chassis Features
Strong, double-cradle steel frame supports a chassis ready for cruising or a full-on tour.
New-generation styling incorporates visual cues from American cruiser heritage: rich paintwork, glittering chrome, and deep front and rear fenders with sculpted ends.
Link-type rear suspension is shaped to mimic the hard-tail lines of a traditional cruiser, connecting a truss-style swingarm and a single shock absorber with seven-way spring preload adjustability, providing 4.1 inches of smooth and responsive suspension travel.
A kicked-out, 33-degree rake and long 65.2-inch wheelbase provide a smooth, comfortable ride.
Stout telescopic front forks deliver generous 5.5 inches of smooth wheel travel.
Wide handlebars, forward-mounted floorboards, and leather-textured seats provide a comfortable ride around town and on the highway.
A wide 15-inch rear tire and matching 16-inch front tire are mounted to bright, spoke-style wheels for a classic cruiser look.
Hydraulic front disc and drum-type rear brakes provide strong, reliable braking performance.
The wide, deeply cushioned seat has a low 27.6-inch seat height that’s ideal for comfortable cruising and confident stops.
Wide passenger seat makes for comfortable two-up rides. Its stepped location on the rear fender allows passengers to see over the rider’s shoulder.
The instrument cluster includes a convenient gear-position indicator, a large fuel meter, and a clock.
A bright multi-reflector headlight is paired with a durable, efficient, and compact LED tail light.
Rear turn signals are mounted at the base of the rear fender to allow room for adding saddlebags.
Additional Features
A variety of Genuine Suzuki Accessories for Boulevard owners are available, including a large selection of Suzuki logo apparel.
12-month unlimited mileage limited warranty. Longer coverage periods with other benefits available through Suzuki Extended Protection (SEP).*
*Subject to separate coverage for certain parts and the exclusions and limitations described in the New On-Road Motorcycle Limited Warranty.
2022 Suzuki Boulevard C50/C50T Photos
2022 Suzuki Boulevard C50/C50T Videos
2021 Suzuki Boulevard C50/C50T Walkaround by Moto Blitz:
Suzuki Boulevard C50 Review by Alex Simmons:
SUZUKI Motorcycles Websites
The post 2022 Suzuki Boulevard C50/C50T [Specs, Features, Photos] appeared first on webBikeWorld.
