2022 Kawasaki KLR 650 Adventure [Model Overview]
Middleweight Adventurer: The 2022 Kawasaki KLR 650 Adventure​
The KLR 650 Adventure is the top-spec KLR model in the 2021 Kawasaki line-up. It’s an impressive motorcycle that takes everything that we already love about the newly revived KLR 650 but fuses it with a shopping list of additional accessories to make it better suited towards adventure travel. If you like your KLR models turned up to eleven, then this is the KLR for you.
This Japanese motorcycle shares almost all of its DNA with the other models in the KLR sub-range. It features the same chassis and styling, as well as the same Euro5 compliant 652 cc liquid-cooled single-cylinder engine that produces 40 horsepower and 39 lb-ft of peak torque. The KLR 650 platform is great, but it’s the number of extras that elevate the Adventure above the others.
For 2021 (though it’s badged as a 2022 model) the KLR 650 Adventure features updated ride ergonomics, new bodywork, a taller windshield, a new larger aluminum rear carrier, a bigger generator, new LED lighting, fog lamps, frame sliders, a tank pad, DC and USB charging, ABS, and adventure-ready side cases—installed by official Kawasaki Motorcycles technicians.
For 2021, the Kawasaki KLR 650 Adventure is available exclusively in a unique Cypher Camo Gray color option.
The 2021 Kawasaki KLR 650 Adventure starts from $7,999 USD / $9,999 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 Kawasaki KLR 650 Adventure in one place.
  • Price: $7,999 USD / $9,999 CAD
    • Updated 652 cc liquid-cooled engine
    • Factory-installed top case
    • DC and USB charging sockets
Main Specs​
  • Engine: 652 cc liquid-cooled single-cylinder engine
  • Power: 40 HP
  • Torque: 39 lb-ft
  • Kerb Weight: 487 lbs (221 kg)
  • Seat Height: 34.3 in (870 mm)
Competitors​
2022 Kawasaki KLR 650 Adventure Specifications​
Engine652 cc liquid-cooled single-cylinder engine
Power40 HP
Bore x Stroke100.0 x 83.0mm
Compression Ratio
9.8:1
Fuel SystemFuel injection: ø40 mm x 1
LubricationForced lubrication, wet sump
ClutchWet multi-disc, manual
Transmission5-speed, return
Final DriveChain
Suspension Frontø41 mm telescopic fork / 200 mm (7.9 in)
Suspension RearUni Trak, single shock with adjustable rebound damping and adjustable spring preload / 185 mm (7.3 in)
Brakes FrontSingle ø300 mm disc with dual-piston caliper
Brakes Rear
ø240 mm disc with dual-piston caliper
Tires Front90/90-21M/C 54S
Tires Rear130/80-17M/C 65S
Fuel Tank Capacity23 litres
Color
Cypher Camo Gray
IgnitionTransistorised ignition
HeadlightLED
Overall Length2,280mm
Overall Width970mm
Overall Height1,540 mm (60.6 in)
Wheelbase60.6 in
Ground Clearance210 mm (8.3 in)
Seat Height870 mm (34.3 in)
Curb Weight221 kg (487 lb)
Warranty12 Months
2022 Kawasaki KLR 650 Adventure Features​
ABS (Anti-lock Brake System)​
2022 Kawasaki KLR 650 Adventure Photos​
2022 Kawasaki KLR 650 Adventure Videos​
Kawasaki Official Websites​
The post 2022 Kawasaki KLR 650 Adventure [Model Overview] appeared first on webBikeWorld.
