The 2022 Indian Scout Bobber Sixty Is the Entry into the Scout Range
The 2022 Indian Scout Bobber Sixty is the most affordable model in the American manufacturer’s Scout range of motorcycles, but it’s still a powerful machine. It borrows its styling cues from the Indian Scout Bobber and shares its smaller 61 cubic inch (1,000cc) engine with the other ‘Sixty’ models.
While the Scout Bobber Sixty looks largely like its older sibling, some differences will let you tell the two apart. For starters, the Scout Bobber Sixty gets black-out valve covers in place of the chrome-plated ones on the regular Bobber. The two also feature different wheel designs and headlight cowls.
Powering the Scout Bobber Sixty is a 1,000cc V-twin engine that produces peak output figures of 78 hp and 65 lb-ft of torque. The engine sends power to the rear wheels via a slick 5-speed gearbox that’s more comfortable at home than on the highway. The performance on offer is ideal even for a slightly newer rider, and the Scout Bobber Sixty is, arguably, the ideal entry into the 2022 Indian Motorcycle lineup.
For 2022, the Scout Bobber Sixty is available in four color schemes — Black Metallic, Black Smoke, Quartz Gray, and Ruby Smoke — with the Black Metallic colorway can be had without ABS.
The 2022 Indian Scout Bobber Sixty starts at $10,749 USD / $12,999 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Indian Scout Bobber Sixty in one place.
Motorcycle Overview
- Price: $10,749 USD / $12,999 CAD
- Bold, low-slung bobber styling
- Low seat height for easy accessibility and control
- Powerful yet approachable 1,000cc V-twin engine
- Engine: 1,000cc V-twin
- Power: 78 hp
- Torque: 65 lb-ft
- Wet Weight: 548 lbs (249 kg)
- Seat Height: 25.6 in (649 mm)
2022 Indian Scout Bobber Sixty Specifications
Engine | 1000cc, Liquid Cooled V-Twin (60 degrees) |
Engine Power | 78 HP |
Bore x Stroke | 3.661 in x 2.898 in (93 mm x 73.6 mm) |
Compression Ratio | 11.0:1 |
Fuel System | Closed loop fuel injection / 54 mm bore |
Exhaust | Split Dual Exhaust w/ Cross-over |
Clutch | Wet, Multi-Plate |
Transmission | 6 Speed |
Final Drive | 2.357 : 1 |
Suspension Front | 41 Telescopic Fork |
Suspension Rear | Dual Shocks |
Brakes Front | Single / 298 mm Rotor / 2 Piston Caliper |
Brakes Rear | Single / 298 mm Rotor / 1 Piston Caliper |
Tires Front | Pirelli Night Dragon 130/90B16 67H |
Tires Rear | Pirelli Night Dragon 150/80B16 77H |
Fuel Tank Capacity | 3.3 gal (12.5 L) |
Color / Graphics | |
Ignition | |
Headlight | LED Headlamp |
Tail Light | LED Taillight |
Overall Length | 87.5 in (2223 mm) |
Overall Width | 36.5 in (926 mm) |
Overall Height | 41.5 in (1,053 mm) |
Wheelbase | 62 in (1,576 mm) |
Ground Clearance | 5.1 in (129 mm) |
Seat Height | 25.6 in (649 mm) |
Weight (Empty Tank / Full of Fuel) | 528 lbs (239 kg) / 548 lbs (249 kg) |
Warranty | 2 Years, Unlimited Miles |
Extension |
2022 Indian Scout Bobber Sixty Features
ICONIC BOBBER STYLING
A side-mounted license plate and tail light with turn signals flaunts the chopped rear fender.Liquid-Cooled V-twin Engine
A blacked-out, liquid-cooled, 60-cubic-inch, 78 hp V-twin engine guarantees a thrilling ride. Electronic fuel injection and liquid cooling are just some of the advanced engineering features giving the Scout Bobber Sixty unmistakable power every time you fire up the engine.ENGINEERED FOR EASE
The lightweight, cast aluminum frame and low seat make for an expertly balanced bike that’s easy to handle at all speeds.MORE ACCESSIBLE THAN EVER
No more excuses. Indian Motorcycle bobber styling, starting at $8,999 with payments as low as $111/month.DESIGNED TO MAKE A STATEMENT
Turn heads wherever you ride with the blacked-out, stripped down bobber styling you want, and nothing you don’t.Full Stop
Eventually, you’ll have to stop. ABS available for superior stopping power.2022 Indian Scout Bobber Sixty Photos
2022 Indian Scout Bobber Sixty Videos
Indian Scout Bobber Sixty Review by BLOCKHEAD:
Indian Scout Bobber Sixty Review by Cycle World:
The post 2022 Indian Scout Bobber Sixty [Specs, Features, Photos] appeared first on webBikeWorld.
