2022 Indian FTR R Carbon [Model Overview]
Indian’s Premium Sports Machine: The 2022 Indian FTR R Carbon​
Badged as a 2022 model, but available in 2021, the all-new Indian FTR R Carbon is a new model for the 2021 Indian line-up that serves as a replacement for the outgoing FTR1200R and FTR Carbon models. It’s a fusion of the best features of the two models, with plenty of impressive upgrades and top-quality components. As far as American-made motorcycles go, this is one of the most impressive on the market.
Like all Indian motorcycles, the new FTR R Carbon is built around a powerful V-twin engine. This one is a 1,203 cc V-twin unit that’s a slight upgrade over the previous models, with a new tune, that produces 120 horsepower and 87 lb-ft of torque but in a more street-friendly package. The engine alone is a thing of beauty.
Other notable features include fully-adjustable Öhlins suspension, Brembo brakes, 17-inch rims, a blacked-out Akrapovič exhaust, selectable ride modes, lean-angle stability control, ABS, wheelie control, and rear cylinder deactivation technology. A fancy 4.3-inch customizable Ride Command system keeps everything under control too. And then there’s the carbon fiber bodywork, which keeps weight down, and looks great!
The Indian FTR R Carbon is available exclusively in Indian’s Carbon Fiber finish.
The 2022 Indian FTR R Carbon starts from $16,999 USD / $19,999 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Indian FTR R Carbon in one place.
Motorcycle Overview​
  • Price: $16,999 USD / $19,999 CAD
    • Carbon fiber bodywork
    • Blacked-out Akrapovic exhaust
    • Adjustable Öhlins suspension
Main Specs​
  • Engine: 1,203 cc twin-cylinder four-stroke engine
  • Power: 120 HP
  • Torque: 87 lb-ft
  • Dry Weight: 479 lbs (217 kg)
  • Seat Height: 30.7 in (780 mm)
Competitors​
2022 Indian FTR R Carbon Specifications​
Engine1,203 cc twin-cylinder four-stroke engine
Engine Power120 HP
Bore x Stroke4.016 in x 2.898 in (102 mm x 73.6 mm)
Compression Ratio12.5:1
Fuel SystemClosed Loop Fuel Injection / 60 mm Bore
ExhaustAkropovic® 2-1-2
ClutchAssist & Slip, Multi-Plate
Transmission6 Speed
Final Drive2.647 : 1
Suspension FrontOhlins Fully Adjustable Inverted Telescopic Cartidge Fork
Suspension RearOhlins Fully Adjustable Piggyback IFP
Brakes FrontBrembo Dual 320mm t5 Rotor / 4 Piston Caliper
Brakes RearBrembo Single 260mm t5 Rotor / 2 Piston Caliper
Tires FrontMetzeler Sportec M9 RR 120/70ZR17 58W
Tires RearMetzeler Sportec M9 RR 180/55ZR17 73W
Fuel Tank Capacity3.4 gal (12.9 L)
Color / GraphicsCarbon Fiber
Ignition
HeadlightLED Headlamp
Tail LightLED Taillight
Overall Length87.5 in (2223 mm)
Overall Width32.7 in (830 mm)
Overall Height51 in (129.5 cm)
Wheelbase60 in (1,524 mm)
Ground Clearance6.5 in (17 cm)
Seat Height30.7 in (780 mm)
Weight (Empty Tank / Full of Fuel)479 lbs (217 kg) / 513 lbs (232 kg)
Warranty2 Years, Unlimited Miles
2022 Indian FTR R Carbon Features​
TOP NOTCH STYLING​
Carbon fiber bodywork and numbered carbon badging constantly remind you just how exclusive your ride really is.
ADJUSTABLE ÖHLINS® SUSPENSION​
Fully adjustable industry-leading Öhlins® forks and piggyback shocks let you customize the ride to perfectly fit your style.
PREMIUM SEAT​
Top-of-the-line seat with paint matched subframe contributes to the striking fit and finish of the FTR R Carbon. You’ll get unmatched comfort–and emotion–every time you sit on it.
NIMBLE HANDLING​
17 in wheels with Metzeler® Sportec® tires and street tuned suspension provide planted cornering, agility, and agile handling.
BLACKED-OUT AKRAPOVIC EXHAUST​
Turn heads with a blacked-out Akrapovič® exhaust and fender to fender carbon fiber.
POISED FOR THRILLS​
Class-leading 87 ft-lbs of torque and 120hp with smooth power delivery to push your heart to the back of your chest and your concerns to the back of your mind.
RIDE MODES​
Sport, Standard, and Rain modes with unique throttle maps and traction control intervention levels give you optimal performance for control in any condition.
RIDE COMMAND 4.3 IN TOUCHSCREEN​
A 4.3 in customizable RIDE COMMAND LCD glove-touch screen with Bluetooth® lets you easily pair your mobile device and control your bike with the touch of your finger.
TAKE CONTROL​
Ride confidently with lean-angle stability control, ABS with cornering pre-control, and wheelie control with rear lift mitigation. Rear Cylinder Deactivation and improved heat management ensure your thoughts are on the road, and not on staying cool.
2022 Indian FTR R Carbon Photos​
2022 Indian FTR R Carbon Videos​
Indian Motorcycle Official Websites​
The post 2022 Indian FTR R Carbon [Model Overview] appeared first on webBikeWorld.
