2022 Honda Super Cub [Specs, Features, Photos]
2022 Honda Super Cub: The Euro-Bike Time Machine
Is it a scooter? Is it a motorcycle? It’s a Super Cub! Since its re-release in US markets back in 2019, the Super Cub scooter has seen steady sales after its initial long-haul when it was first released 60 years ago by Honda Motorcycles.
The Super Cub has seen little to no changes since its 2019 re-release, but that’s for good reason. With a model that has recently undergone a complete redux based on a platform that is over 60 years old, what could you possibly improve upon? Honda is finally breaking the mould this year with the introduction of a sleek, all black colorway featuring blacked out components and wheels. This sleek colorway is definitely out of the ordinary for a model that prides itself on its Japanese heritage colors, but it looks so good you can’t help but welcome it with open arms.
The Super Cub is powered by the same engine found in the Honda Grom and Monkey; a 124.9cc air-cooled single-cylinder mill that churns out a steady 9.1 horsepower and 7.7 lb-ft of torque. Although these power figures are nothing to bat an eye at, the Super Cub shines thanks to its high level of manouverabiliy as a direct result of its 240lb wet weight.
The 2022 Honda Super Cub starts at $3,799 USD / NA CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Honda Super Cub in one place.
  • Price: $3,799 USD / NA CAD
    • Anti-lock brakes
    • Low seat height
    • LED lights
Main Specs​
  • Engine: 124.9cc air-cooled, single-cylinder, four-stroke
  • Power: 9 horsepower
  • Wet Weight: 240 lbs (108 kg)
  • Seat Height: 764 mm (30.1 in.) at lowest point
Competitors​
2022 Honda Super Cub Specifications​
Engine124cc air-cooled single-cylinder four-stroke
Power9 horsepower
Bore x Stroke50mm x 63.1mm
Compression Ratio10.0:1
InductionPGM-FI with automatic enrichment
Starter
Valve TrainSOHC; two valves per cylinder
ClutchAutomatic centrifugal
TransmissionFour-speed semi-automatic
Final Drive#420 Chain; 14T/36T
Suspension Front26mm telescopic fork; 3.5 inches travel
Suspension RearTwin shock; 3.6 inches travel
Brakes FrontSingle 220mm hydraulic disc; ABS
Brakes RearMechanical drum
Tires Front70/90-17
Tires Rear80/90-17
Fuel Tank Capacity1.0 gallon
ColorMatte Gray Metallic
IgnitionFully transistorized
Headlight
Tail Light
Overall Length
Ground Clearance
Trail2.8 inches
Wheelbase48.9 inches
Rake (Caster Angle)26°
Seat Height30.7 inches
Curb Weight238 pounds (Includes all standard equipment, required fluids and full tank of fuel—ready to ride)
WarrantyUnlimited-mileage, limited warranty
2022 Honda Super Cub Features​
PERFORMANCE​
125cc FUEL-INJECTED ENGINE
Nobody can match the Honda reputation for engines, and even though the Super Cub is relatively compact, it’s a giant in terms of performance and reliability.
EASY TO PARK
Because the Super Cub is compact, it’s easy to park in the city, and to store when you’re not riding. There’s always room for a Super Cub!
HYDRAULIC FRONT DISC BRAKE
The Super Cub features a 220mm front single disc brake for excellent stopping power. There’s even standard front-wheel ABS.
TECHNOLOGY​
FOUR-SPEED SEMI-AUTOMATIC TRANSMISSION
The Super Cub features a four-speed semi-automatic transmission that you shift with your left foot, like a traditional motorcycle. But here’s the unique feature: there’s no clutch to worry about—you just toe and go.
ELECTRIC SEAT OPENER
Need to release the seat latch for a fill-up? Just press a button—the lock is all electronically controlled on the Super Cub.
LED LIGHTING
Old-school light bulbs may have been great in 1959, but 60 years later the Super Cub comes with a modern LED lighting package.
SMART KEY
Just like our top-of-the-line Gold Wing, the Super Cub uses a convenient smart-key ignition.
STYLE​
STEP-THROUGH CHASSIS
This is one of the key design elements which made the original Cub so popular. The Super Cub’s step-through design incorporates frontal bodywork to help shield you from the wind and road splash. It’s not only super convenient, but makes it easy to get on and off the bike.
LOW SEAT HEIGHT
At just 30.7 inches, the Super Cub’s super-low seat makes it easy to flat-foot it in parking lots or at stop lights.
MULTI-FUNCTION DIGITAL INSTRUMENTS
Retro meets modern in the Super Cub’s instruments. The faired-in handlebar-mounted features speedometer, odometer, A&B trip meters, fuel gauge, clock, and indicator for low/high beam.
ROUND HEADLIGHT
The Super Cub’s round headlight looks retro, but its LED performance is totally up to date and provides superior illumination and visibility.
UNDERSEAT FUEL TANK
With its 1.0-gallon fuel tank and awesome fuel efficiency, the Super Cub is super practical. The tank filler is under the seat so it’s easy to access.
HANDLING​
STANDARD ABS
Our front-wheel Anti-Lock Braking System (comes standard on the Super Cub) can be a big help in making controlled stops in less-than-ideal conditions, like on wet pavement or other compromised surfaces. It’s a great feature whether you’re using your new bike as a commuter or just riding it for fun, since it helps you stop with added confidence.
17-INCH CAST WHEELS
Big enough to roll along smoothly, the machine-finished cast construction on these wheels means they’re easier to keep clean than the traditional spoke construction.
FRONT SUSPENSION
The Super Cub’s telescopic front suspension is partially faired in, blending with the upper bodywork. It looks awesome, and works a lot better than the original leading-link design.
TUBELESS TIRES
Here’s another thoroughly modern touch: The Super Cub uses tubeless tires.
TWIN REAR SHOCKS
The original Cub had twin shocks, and so does the 2022 Super Cub. They not only look proper, but they also do a great job of smoothing out the road.
2022 Honda Super Cub Photos​
2022 Honda Super Cub 2022 Honda Super Cub 2022 Honda Super Cub 2022 Honda Super Cub
2022 Honda Super Cub Videos​
Honda C125 Super Cub – full road test and review
New 2022 Honda Super Cub
Honda Websites​
Other Links​
The post 2022 Honda Super Cub [Specs, Features, Photos] appeared first on webBikeWorld.
