2022 Harley Davidson Road King [Specs, Features, Photos]
The 2022 Harley Davidson Road King: A True Classic
The Road King remains as the retro-modern bagger in the 2022 Harley Davidson lineup. Under the familiar classic fenders, modern Reflex Brembo ABS brakes maintain control of the Slicer 2 cast wheels. The Hiawatha headlamp and generous use of chrome maintain the 60s vibe.
The smooth 110 lbs-ft of torque from the Milwaukee-Eight® 107 V-twin, easily power you down the highway, enjoying mile after mile listening to the classic Harley Davidson rumble. A removable fork-mounted fairing keeps the wind off your chest, and the one-touch opening hard bags hold plenty for longer trips. A true American-made motorcycle.
3 colors for the 2022 Harley Davidson Road King: Vivid Black, Midnight Crimson & Gauntlet Gray Metallic
The 2022 Harley Davidson Road King starts at $19,929 USD / $23,999 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Harley Davidson Road King in one place.
  • Price: $19,929 USD / $23,999 CAD
    • Reflex
      Defensive Rider System (Rdrs) Optional
    • One-Touch Opening Saddlebags
    • ABS & Cruise Control Standard
    • Removable Fairing
Main Specs​
  • Engine: 107 ci V-twin
  • Power: 92.5 HP (estimated)
  • Torque: 110 lbs-ft @ 3000 RPM
  • Wet Weight: 828 lbs (375 kg)
  • Seat Height: 26.3 inches (705 mm)
Competitors​
2022 Harley Davidson Road King Specifications​
EngineMilwaukee-Eight® 107
Engine Torque111 ft-lb
Bore x Stroke3.937 in. X 4.374 in.
Compression Ratio
10.0:1
Starter
ExhaustChrome, 2-1-2 dual exhaust with tapered mufflers
Clutch
Transmission6-speed
Primary Drive
Gear, 34/46 ratio
Front Fork
49 mm Dual Bending Valve
Rear Shocks
Premium standard height hand-adjustable rear suspension
Wheels, Front Type
Slicer II Cast Aluminum
Wheels, Rear Type
Brakes Front
32 mm
Brakes Rear4-piston fixed
Tires Front
BW 130/70B18 63H
Tires Rear
BW 180/55B18 80H
Fuel Tank Capacity6 gal.
ColorVivid black, Midnight Crimson, Gauntlet, Gray Metallic/Vivid Black
Ignition
HeadlightAll LED headlamp
Length
96.5 in.
Trail
6.7 in.
Rake26
Wheelbase
64 in.
Ground Clearance
5.3 in.
Seat Height
26.3 in.
Weight, As Shipped
794 lb.
Warranty
2022 Harley Davidson Road King Features​
MILWAUKEE-EIGHT® 107 ENGINE​
A powerful, smooth-running engine with crisp throttle response and a pure, soul-satisfying rumble.
REFLEX
LINKED BREMBO® BRAKES WITH STANDARD ABS​
Designed to help prevent the wheels from locking under braking to assist the rider in maintaining control when braking in a straight-line. ABS operates independently on front and rear brakes to keep the wheels rolling and help prevent uncontrolled wheel lock in urgent situations.
HIAWATHA HEADLAMP AND NACELLE​
Born in the ’60s, when chrome ruled the streets. Big and commanding, it’s built with the latest in materials and technology for a long distance high beam and wide low beam.
RESPONSIVE SUSPENSION​
High-performing front and rear suspension, with easily hand-adjustable rear shocks put you in control of a plush ride.
ONE-TOUCH OPENING SADDLEBAGS​
Tight on the outside, roomy on the inside. The hinges are simple and clean and the lids open with one touch of one hand.
2022 Harley Davidson Road King Photos​
2022 Harley Davidson Road King 2022 Harley Davidson Road King 2022 Harley Davidson Road King 2022 Harley Davidson Road King
2022 Harley Davidson Road King Videos​
2022 Harley Davidson Road King VS. Road King Special:
Why the Road King is the BEST Harley-Davidson you can buy:
The post 2022 Harley Davidson Road King [Specs, Features, Photos] appeared first on webBikeWorld.
