2022 Harley Davidson CVO Road Glide Limited [Specs, Features, Photos]
The 2022 Harley Davidson CVO Road Glide Limited: Best In Class
CVO is recognized as the absolute best by Harley Davidson, and the best is what touring riders in this segment demand. The CVO Road Glide Limited is built around the Milwaukee-Eight® 117 V-Twin engine, which is currently the most-powerful engine offered in the 2022 Harley Davidson lineup. Making a strong 126 ft. lbs. of torque, the 117 moves the CVO Road Glide Limited with ease when fully loaded.
Many American manufacturers have luxury touring machines in their lineups, but nothing else comes close to the level of fit and finish of the CVO series, this is a bespoke touring machine.
Full-on custom treatments from fender to fender. You get custom seat covers and stitching with a backrest, Tomahawk front 19-inch, and rear 18-inch wheels, Daymaker® Adaptive LED headlamps with lean angle activation, Reflex
Defensive Rider System electronic safety aids, and the incredible Stage II Harley-Davidson® Audio system powered by Rockford Fosgate.
3 Color choices for the 2022 Harley Davidson CVO Road Glide Limited:
  • Wicked Orange Pearl
  • Hightail Yeloow Pearl
  • Dante’s Red Fade
The 2022 Harley Davidson CVO Road Glide Limited starts at $44,899 USD / $53,799 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Harley Davidson CVO Road Glide Limited in one place.
  • Price: $44,899 USD / $53,799 CAD
    • Milwaukee-Eight® 117 V-Twin engine
    • Harley-Davidson® Audio powered by Rockford Fosgate® Stage II
    • Daymaker LED Headlight
    • Tomahawk
      Front 19-inch and Rear 18-inch wheels Gloss Black and Contrast Satin
Main Specs​
  • Engine: 117 ci V-twin
  • Power: 105 HP (estimated)
  • Torque: 126 lbs-ft @ 3750 RPM
  • Wet Weight: 963 lb. (437 kg)
  • Seat Height: 28.2 in. (716 mm)
Competitors​
2022 Harley Davidson CVO Road Glide Limited Specifications​
EngineMilwaukee-Eight® 117
Engine Torque126 ft-lb
Bore x Stroke4.075 in. x 4.5 in.
Compression Ratio
10.2:1
Starter
ExhaustDual, with crossover
Clutch
Transmission6-speed
Primary Drive
Gear, 34/46 ratio
Front Fork
49mm Dual Bending Valve
Rear Shocks
Premium standard height hand-adjustable rear suspension
Wheels, Front Type
Gloss Black and Contrast Chrome Tomahawk
Wheels, Rear Type
Brakes Front
32mm, Dual floating rotors
Brakes Rear4-piston fixed
Tires Front
BW 130/60B19 61H
Tires Rear
BW 180/55B18 80H
Fuel Tank Capacity6 gal.
ColorWicked Orange Pearl, Hightail Yellow Pearl, Dante’s Red Fade
Ignition
HeadlightAll LED headlamp
Length
101.2 in.
Trail
6.7 in.
Rake26
Wheelbase
64 in.
Ground Clearance
5.1 in.
Seat Height
28.2 in.
Weight, As Shipped
927 lb.
Warranty
2022 Harley Davidson CVO Road Glide Limited Features​
Power​
Milwaukee-Eight 117 V-Twin
The new pinnacle of torque and displacement with a factory-installed powertrain. Precision oil/air cooling. 126 ft. lbs. of torque at 3750 RPM. Tuned heavy breather intake and high flow exhaust maximize engine performance, a boost you can feel with every twist of the throttle.
Style​
Premium paints and finishes
Heated Kahuna Collection hand grips match Kahuna shifter pegs, brake pedal cover, muffler end caps, heated grips and rider and passenger boards
Fugitive custom wheels
The Ride​
All the features you need for a ride that feels comfortable and rides secure.
H-D Touring Chassis
Daymaker Adaptive LED headlamp and bright LED lighting for enhanced visibility
Corner Safety Enhancements
Harley-Davidson® Audio powered Rockford Fosgate​
Step up to the ultimate motorcycle audio experience. Harley-Davidson Audio powered by Rockford Fosgate Stage II speakers deliver ultra-clear highs, super clean mids, and ground thumping bass. These amplified three-way speakers feature a durable injection molded woofer and a separate bridge-mounted Midrange and Tweeter speakers.
Boom! Box GTS Infotainment​
Nothing standard about this state-of-the-art system with color touch screen, two fairing-mount speakers and hidden radio antenna. Every element is optimized to enhance the rider’s interaction with the bike and connectivity with the world.
2022 Harley Davidson CVO Road Glide Limited Photos​
2022 Harley Davidson CVO Road Glide Limited 2022 Harley Davidson CVO Road Glide Limited 2022 Harley Davidson CVO Road Glide Limited 2022 Harley Davidson CVO Road Glide Limited
2022 Harley Davidson CVO Road Glide Limited Videos​
I Test Rode The 2022 CVO Road Glide Limited!!
2022 CVO Road Glide Limited Test Ride & Review | I Finally Understand:
The post 2022 Harley Davidson CVO Road Glide Limited [Specs, Features, Photos] appeared first on webBikeWorld.
