2021 Harley Davidson Street Glide [Model Overview]
The 2021 Harley Davidson Street Glide: The Batwing Bagger​
The original stripped-down American hot rod bagger, the Street Glide has long set the bar for doing this style right. Powered by the Milwaukee-Eight® 107 engine with 92 HP and 110 lbs-ft of torque, plenty of jam is always on tap backing up the badass looks.
The Harley Davidson Street Glide is known for the iconic fork-mounted fairing, the Batwing cuts a smooth path through the air offering rider protection and a home for the standard Boom!
Box GTS Infotainment System.
In the 2021 Harley Davidson lineup, three versions of the Street Glide are available. Unchanged from last year’s model, this first level of the Street Glide comes with one-touch opening hard bags, Brembo ABS brakes, and floorboards all standard. The Reflex
Defensive Rider Systems collection of technologies is optional.
3 Color choices for the 2021 Harley Davidson Street Glide: Vivid Black, Billiard Red, and River Rock Gray.
The 2021 Harley Davidson Street Glide starts at $21,999 USD / $26,999 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 Harley Davidson Street Glide in one place.
  • Price: $21,999 USD / $26,999 CAD
    • Milwaukee-Eight® 107 V-Twin engine
    • Standard Brembo ABS
    • Cruise Control
    • Boom!
      Box Gts Infotainment System
Main Specs​
  • Engine: 107 ci V-twin
  • Power: 92.5 HP (estimated)
  • Torque: 110 lbs-ft @ 3000 RPM
  • Wet Weight: 829 lbs (376 kg)
  • Seat Height: 26.1 inches (695 mm)
Competitors​
2021 Harley Davidson Street Glide Specifications​
Engine107 ci V-twin, Milwaukee-Eight® 107 V-Twin engine
Engine Torque110 lbs-ft @ 3000 RPM
Bore x Stroke3.937 in. in x 4.375 in
Compression Ratio
10.0:1
ExhaustChrome, 2-1-2 dual exhaust with tapered mufflers
Clutch
Transmission6-speed
Primary Drive
Chain, 34/46 ratio
Wheels, Front Type
Enforcer II Cast Aluminum
Wheels, Rear Type
Brakes Front32 mm, 4-piston fixed
Brakes Rear32 mm, 4-piston fixed
Tires Front
130/60B19 61H
Tires Rear
BW 180/55B18 80H
Fuel Tank Capacity6 gal.
ColorVivid Black, Billiard Red, and River Rock Gray
Ignition
HeadlightHigh beam
Overall Length
96.5 in.
Trail6.7 in.
Rake26
Wheelbase
64 in
Ground Clearance5.3 in..
Seat Height
26.1 in.
Weight, As Shipped796 lb
Warranty
2021 Harley Davidson Street Glide Features​
Milwaukee-Eight® 107 Engine​
A powerful, smooth-running engine with crisp throttle response and a pure, soul-satisfying rumble.
Reflex
Linked Brembo® Brakes with Standard ABS​
Designed to help prevent the wheels from locking under braking to assist the rider in maintaining control when braking in a straight-line. ABS operates independently on front and rear brakes to keep the wheels rolling and help prevent uncontrolled wheel lock in urgent situations.
BOOM!
Box GTS Infotainment System​
An evolved interface experience that offers a contemporary look, feel and function, with exceptional durability and features designed specifically for motorcycling. Every element is optimized to enhance the rider’s interaction with the bike and connectivity with the world.
Batwing Fairing​
The Batwing fairing has an iconic shape with a sleek, progressive style that delivers smooth air flow and reduced head buffeting.
Responsive Suspension​
High-performing front and rear suspension with easily hand-adjustable rear shocks put you in control of a plush ride.
2021 Harley Davidson Street Glide Photos​
MY21 Key Features. Street Glide.
MY21 360 Web
2021 Harley Davidson Street Glide Videos​
The post 2021 Harley Davidson Street Glide [Model Overview] appeared first on webBikeWorld.
