2021 BMW S 1000 R [Model Overview]
BMW’s Naked Roadster: The 2021 BMW S 1000 R​
The S 1000 R is a super-naked sportbike that is virtually all-new for this year, making it one of the most heavily updated models in the entire 2021 BMW line-up. This European-made naked machine is an unfaired powerhouse, with an attitude that toes the line between practical roadster and supersports riding perfectly.
For 2021, the S 1000 R has received a number of exciting updates. The most obvious of these include a redesigned chassis that significantly reduces the bike’s overall weight and new aesthetics that give the S 1000 R a more aggressive street-ready look.
The S 1000 R is powered by a retuned version of the S 1000 RR’s mighty 9,99cc inline-four engine. The power is rated at 165 horses and 84 lb-ft of peak torque. For 2021, the S 1000 R enjoys new gear ratios for improved torque and a quiet and smoother operation. Two riding modes come as standard, along with ABS and ASC (that can both be disengaged), an anti-hopping clutch, a drop sensor, LED lights, and an HP titanium slip-on exhaust.
Optional extras include Ride Modes Pro (with ABS Pro, Launch Control, and Pit Lane Limiter), and Gear Shift Assist Pro for dynamic and effortless shifting.
For 2021, the S 1000 R is available in three color options: Black Storm Metallic, San Marino Blue, and BMW Motorrad’s Light White/Lupin Blue Metallic/Racing Red tricolor.
The 2021 BMW S 1000 R starts at $14,995 USD / $16,500 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 BMW S 1000 R in one place.
2021 BMW S 1000 R
  • Price: $14,995 USD / $16,500 CAD
    • High-performance 4-cylinder in-line engine
    • Race ABS, ASC, and two Ride Modes as standard
    • Optional ride Modes Pro with ABS Pro, DTC, Launch Control, and pit lane limiter
    • Optional Gear Shift Assist Pro for dynamic shifting
  • Engine: 999 cc liquid-cooled 4-stroke in-line 4-cylinder engine
  • Power: 165 HP
  • Torque: 84 lbs-ft
  • Wet Weight: 452 lbs (205 kg)
  • Seat Height: 32 in (810 mm)
2021 BMW S 1000 R
2021 BMW S 1000 R Specifications​
Engine 999 cc liquid-cooled 4-stroke in-line 4-cylinder engine
Engine Power165 Hp
Bore x Stroke80 mm x 49.7 mm
Compression Ratio12.1 : 1
Fuel deliveryElectronic fuel injection with ride-by-wire throttle system and knock sensor
Max Torque84 lb-ft (114 Nm) at 9,250 rpm
ClutchMulti-disc clutch in oil bath, anti-hopping clutch, mechanically operated
TransmissionConstant-mesh 6-speed gearbox with straight cut gears
DriveChain 2.647:1
Suspension FrontUpside-down telescopic fork Ø 46 mm, compression and rebound stage adjustable
Suspension RearAluminum 2-sided swing arm, rebound damping adjustable
Brakes FrontDual floating disc brakes, 4-piston fixed calipers, diameter 320 mm
Brakes RearSingle disc brake, diameter 220 mm, single piston floating caliper
Tires Front120/70 ZR 17
Tires Rear190/55 ZR 17
Fuel Tank Capacity4.6 gal (17.5 l)
ColorBlack Storm Metallic
AlternatorThree-phase 406 W generator
Battery12 V / 9 Ah, maintenance-free
HeadlightLED headlight
Tail LightLED Tail Light
Overall Length81.0” (2,057 mm)
Overall Width33.3” (845 mm)
Overall Height48.3” (1,228 mm)
Wheelbase56.7” (1,439 mm)
Castor3.9” (98.5 mm)
Seat HeightStandard Seat: 32″, Comfort Seat: 33.1″
Unladen weight, road ready, fully fueled
452 lbs (205 kg)
Warranty
2021 BMW S 1000 R
2021 BMW S 1000 R Features​
Distinctive front.​
The asymmetrical headlamp arrangement makes the RR’s DNA easy to recognize.
Prominent "R" logo.​
Underlines the leading position of the S 1000 R in the dynamic roadster segment.
Multifunctional instrument cluster.​
With round speedometer, indicator lamps and a large, easy to read LCD display.
Light aluminum tank.​
Made of aluminum, the slim fuel tank reduces the overall weight.
Reduced side trim.​
The reduced and dynamic trim supports the sporty and aggressive design.
High-performance brakes.​
For outstanding braking performance and braking safety.
Optional Gear Shift Assist Pro.
Ensures dynamically quick shifting.​
HP titanium rear exhaust as standard.​
The HP rear exhaust made of titanium and fitted as standard provides a powerful sound.
2021 BMW S 1000 R Photos​
2021 BMW S 1000 R
2021 BMW S 1000 R
2021 BMW S 1000 R
2021 BMW S 1000 R
2021 BMW S 1000 R Videos​
BMW Official Websites​
The post 2021 BMW S 1000 R [Model Overview] appeared first on webBikeWorld.
